All
I have searched the forums but have not been able to find the answer.
Basically I have traced a misfire issue to what seems to be the Ignitor - we had the car on the Dyno today, changed the Ignitor and the bad misfire between 3000 - 4000 when load comes on hard went away. We checked the coils (Spitfire) and the mechanic seemed sure it was the ignitor, as we tried 2 standard coils but same problem. Also we changed spark plugs, so eliminated that issue.
However, after driving the car a good 40km the problem is back??? I have a new G4 ecu, and the car has been fully tuned, mapped last week.
Do you think the ignitor is still the issue - the one we changed it to was not new?
If I get a HKS Twin Spark amplifier does that mean I wont need the ignitor?
Any other ideas?
https://www.sau.com.au/forums/topic/272326-ignitor-issues-i-think/
well if changing the ignitor solved the issue last time you would assume at least some of the problem lies there.
what plugs did you put in? and how old are the coilpacks? if the coilpacks are old then they might be struggling. and it your spark plugs are gapped at 1.1mm that won't be helping the situation either.
I had the same problem as yourself on the dyno my R32 GTR missfired from 3k to 4000 rpm badly.
I replaced my stock rb26 coils with the split fires and it was better, still we didnt know why, so then gapped the plugs down to .6mm was slightly better again bacause of small gappin, but still could not dyno car properly bacause of miss fire.
So after all this stuffing around i when out and bought 3mm cable and made extra custom earths for ignitor, engine , alloy rad, and notice a big improvement and the problem solver was changing the IGNITOR itself i got a good second hand one and by luck it worked fine then presto, the miss fire problems went and i was able to bump up the plug gapping up to .8mm and made more power cleaner and isues gone.
I think your ignitor could still be the problem if its second hand remember they are 15yr plus old now so finding a good cond old one is hard.
Cheers,
Dave.
yep, my money is on G4 cooking the ignitor, or possibly faulty earthing. both are easy to check/remedy.
and no, the HKS DLI does not replace the ignitor. it's just added to the system.
  • 1 month later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
