Eoi: White Te37's -[melb]
Hey boys/girls.
Thinking of Sellin my TE37's... not sure yet as i dont have any rims to put on the car if i was to sell em..
Wheel Spec's:
White TE37's
front: 17x8.5 +30
rear: 17x8.5 +30
For those who dont know what they look like. (I'm sure there is always 1. lol) Here is a pic!
They have RE01-R's on em.. 80ish% thred.
EOI price: 2.5k
Edited by Royalflush
Interested in your rims mate.
Can you measure how many mm till the wear indicator on the tyres?
Any damages on the rims?
Can you send me photos to [email protected]
Thanks
Measure how many mm till the wear indicator? Um yea ok.. Unless you want to come sus em out for your self?
No damages on the rims what so ever mate!
I'll send you a pic of the actual wheels later on this week..
Not a fan myself... probably would suit an Integra but not a Skyline imo.
WHAT THE F**K?!
What a waste to put these wheels on an Integra!
Rays Engineering - Volk Racing TE 37's are one of the best wheels to come from Japan and you reckon to put it on an Integra.
:P
:mad:
The looks friggin tuff on GTR's.
LMFAO! :D
Spunky Munky you say some stupid things on SAU I can't help but laugh!
It's not a personal attack, all cool! :D
Back On Topic.
Royalflush, have you got a price in mind?
Selling these wheels with no tyres you can easily get $2000+
But depending on the condition of the wheels too, gutter rashes, scratches, paint etc...
I would keep them as I have set of 17" TE37's myself and they are very nice wheels.
Hey Dude, Thanks for your Input. Weird people have weird taste i guess. Spunky Munky maybe like Cromies?
After a few PM's over the past few days. I've came to the conclusion to leave the price @ $2500 FIRM
If they don't sell I'll just keep em. They have no damages on em so they in good condition. just needs a clean I guess.
RE01-R's are pretty hard to get too... So they a rear find.
Going back to how much tred is left on them, i would like to take my estimate back. As some people measure them differently. But Personally I believe they around maybe 80ish% tread left on them :banana:
Removed the wheels off the car and bought them home. At closer inspection I noticed some small marks on the wheels. The one that has been marked by a 5 cent coin and taken picture of has is the most damaged.
Wheels can be inspected anytime. Located in Melbourne Western Suburbs.
Contact me via PM's.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
