No offence but has the VIpec been tested with a new engine configuration - as in mutiple cam control, DBW control, knock sensor retard functions? This is one area where all aftermarket ECU's seem to fall over. I'm yet to see an aftermarket ECU control Cams better than the factory ECU in almost all applications let alone DBW control - f**k me, most even struggle with stepper motor control!
You would think by now that most aftermarket ecu's would be at least able to deliver consistant injector and ignition control -but I've seen issues with all the big name ECU's - including Haltech, Motec and Autronic!!
On a side note I had a look at the Vipec interface - looks rather clumbsy! Was it copied from Motec?
we will be doing a fair few fully variable cam setups soon, Evo IX, SR20VE headed monster so i will let you know how it goes with cam control, so far the only other ecu ive done on similar setups was autronic and greddy v-manage (the later was suprisingly good on an evo 8)
The software is carried over from LINK's previous G3 range of ecu's, its actually quite nice to use, no-where near as cumbersome as motecs. I probably tune on average 5 different types of ecu each week and remmbering hotkeys is a nightmare.
Edited by URAS
  • Replies 85
[quote name='URAS' date='24 Jun 2009, 12:28 AM' post='4675229 doing a fair few fully variable cam setups soon, Evo IX, SR20VE headed monster so i will let you know how it goes with cam control, so far the only other ecu ive done on similar setups was autronic and greddy v-manage (the later was suprisingly good on an evo 8)
I tune lots of factory systems and aftermarket systems. From what I've seen the Autronic SM4 is the closest thing to factory level managment with an interface that is simple and quick to tune with. You can frig around with motecs to get them somewhere but they are missing silly things like delta ignition control (can be setup using rpm as an axis but its not a delta number from the desired idle speed) and their PI control is shit not to mention so slow to tune.
At a glance the Link looks similar to the autronic but the interface is where it may fall over even if they tune ok.
Does the link use the desired AFR map as an enrichment map like the autronic does and then you just tune the VE? And is there a charge air temp cal?
with the launch control and antilag and whatever else would i need something ontop of the computer to use the features? like a handcontroller or something? and do they have to be set up and is it hard or would it be included in the fitting and tuning price if i chose ot use them?
  • 1 month later...
launch control, flat shifting and anti-lag need switches wired in to the digital inputs on the ECU to function, other than that its all in the software setup.
are there any other functions you would wire a switch to?
You can trigger multiple things off the one switch for example i have launch control and flat shift off the same switch (i used the factory clutch switch rewired) in the software there is a 6 second time delay on the clutch being depressed and launch control activating then the switch also works normally for the flat shifting.
The only other switch i have wired in is for the dual fuel/ignition map switching. if i want to turn anti-lag on i would have to do so via a laptop which isn't a big deal assuming you weren't switching it on and off a lot.
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
