hey guys,
quick update.
Riverside Infiniti are sending out the Gaskets. a big thank you to Tony from R.I. as soon as they arrive i will post that the kit is available to collect / post out.
Even though they claim they sent them, they clearly were not in the box when they arrived. So i dont know what has happened. I think they may have misplaced the package with the gaskets.
-mark
  • Replies 46
  • 3 weeks later...
Hey Mark,
Picked up the package from the post office on Monday. Thanks a lot for organising the group buy, fantastic work.
I'll be installing it shortly, together with the grounding kit, which should arrive next week.
  • 5 weeks later...
from my post on 350z tech:
finally got around to installing my thermo spacer kit yesterday quick check all good and took for a moderate drive...maybe a little crisper/strong through the rev range, but nothing earth shattering. Got home tonight and re-did the ECU tricks:
1. throttle valve closed reset
2. Accel pedal released learning
3. idle air volume
4. reset ECU (2x last night did not get the timing right, but the check engine doing it fast --> slow flash wiping memory clean tonight.
Car was hot from a 25km commute home, so this time I though gotta try WOT - afterall that's when the short-comings of the old plennum would've been apparent. Wowwee! different car now with my twin 60mm S/S exhaust + 5/16 Thermo plennum spacer kit. Above 5k rpm WOT I sang 'turbo' as it came on song. What hoot, very worthwhile for $280 and 3 hrs careful install. Not a thing out of place with the kit - other than I added couple more washers myself and used 6 of them for the strut brace bolts as the included bolts do not have integrated washers like the OEM bolts.
