hey peoples, i was just looking for some help on a little battery/defect problem i have atm. i got defected the other day cause my battery is just sittin in the mount in the boot and not sealed or vented. now my problem is in 2 parts :) first part is, is a sealed battery and a dry cell battery the same thing?? ....can i just buy a sealed battery and connect the lil breathe hose and it'll b legit? or do i have to get one of them big containers and put the battery in that?
if ive explained it wrong or u need more info just let me know k...thanks people..
https://www.sau.com.au/forums/topic/272417-need-help-about-sealed-batterys-plz/
How much u wana spend.. $$$ id go for a dry cell.... one of the optima batterys. theys wikid i can leave my radio on all day.. verry good for the money and iv neva had to have a jump start since iv got it.. their about $400 tho
i had this same defect...
there is a battery you can buy from supercheap that fits your line pretty well much perfect. you need one of the european ones that has the adaptor for the hose. you must have this otherwise the battery is not venting. the battery does not have to be in an enclosure, just needs to be a sealed one with the venting pipe to outside the car.
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
