  • Replies 40
im not going to attemt all this by myself as i am not experianced in working on the vehicle myself. trying to elarn but yer... lol. and it doesent help when i have a hybrid pipeing systam wich pretty much wont let me access my coilpacks lol.
thanks =)
I've got almost no mechanical knowledge and i still managed to put in Splitfires and new plugs in my car. I've got a hybrid kit as well but it didn't pose any extra trouble. Hardest part is getting clear access to them, once you've got to them rest is easy. Think there are a few guides floating around on here too if you do a search.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4637537
  • 1 month later...
Provided its small, direct jobs which require little instruction (attach front bar, paint car etc) Jerry does a good job, and if he stuffs up he will fix it for free. But do note that he doesnt do mechanical or electrical anymore. He will send your car to Fast and Furious automotive for anything mechanical and will get a 3rd party electrical to do anything electrical.
But when it comes to bodykits, paint work, customising bodykits (he even makes some of his own) and anything external he is great.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4755913
  • 4 weeks later...
So in Canberra there is:
ESP
Trojan
Autotech
Ultimate Tunes
J Racing
Anywhere else? It would be good to compare the hourly rates of each place also.
I need a pair of turbos (probably -5s), them to be fitted and the car tuned.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4805461
So for those of you who have seen my car :) *most of you i think* Do you think J Racing could colour match my pink and pearl?? I need to put my new front bar on my baby and I am super paranoid about getting good colour matching!! lol
:D
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4805938
Jerry's shop did my front bar Repair+Paint. The shade was off somewhat so he got his guys to do it all again without any whinge by me. Second time spot on at no additional cost to me. That was my experience :)
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4806073
If my bar just has a simple crack in the front, where it got pushed back into the cooler by a gutter (what a meanie gutter it was! :)) and a few more minor cracks on the underside from driveways etc, would you recommend taking it to Jerry? I wasn't aware JR would be in the business of repairs, figured they only did fitting and fabrication.
what was your damage and how much did it cost you sinista? I've got my own can of paint (which doesn't quite match as the front end of my car is slightly darker than the fuel cap cover I got it matched to lol), do you think they'd use it so I could save a little? obviously I can't expect them to guarantee the paint if I supplied it, but it doesn't bother me much.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810547
My lower front bar lip was cracked all the way through 6-8inches long and a few minor abrassions from the dreaded gutters. You can't tell it was ever cracked and they also secured it all the way round properly (not zip ties). Cost to me repaired, preped, re-sprayed and fitted was $400.
JR will do what you ask for. If you want to spray it your self from pressure pack/s then I'm sure he wont have an issue. they should just do the fibre glass repairs. Thats what they do when not fitting full body kits.
Like verything else you get what you pay for and there is good n bad experiences. Even J Racing doesn't have 100% customer satisfaction. That said my experience with J Racing was good.
PS. As said earlier they dont do mechanical and will refer on :)
Edited by Sinista32
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810603
That's an acceptable price, I think I'll definitely head round there lunchtime Monday and maybe tee something up with them.
Your damage is more or less the same as mine, but yours sounds a little worse from the length of the crack lol :)
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810615
Got my car back with the bumper repaired from JR today, must say they did a rather acceptable job on it!
Mounted it correctly, and you can hardly tell it was repaired (though naturally if you look closely it's not 100% new looking, few imperfections but who cares)
The only downside of it was the cost, $480 removed, repaired, painted, and refitted. Though considering I walked in Monday to inquire about it and he took it in Tuesday to begin the repairs, can't complain about the turnaround :cool:
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4833972
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
