found a pretty good build on ausrotary (think u need to b a member to see it so ill pop a few goodies here)
here is his photobucket album if u wanna troll
hey all, im building a full tube chassis Ford powered 1991 Dodge Daytona, it will have a 4.6L Ford Mustang Cobra V8, 2 x Garrett GT42R turbo's, 2 x TurboSmart Pro-Gate 50 WasteGates, 2 x TurboSmart Race Port Blow off Valves, Ported Ford Cylinder Heads, Comp Cams, Forged Ford Crasnkshaft, custom Diamond Pistons and custom Manley Rods, Motec M800 ECU, MOTEC CDI, CDI Marine Coils, Mark Williams 40-spline 9.5'' Diff, Mark Williams Carbon Fibre Driveshaft, Romac 4-Link Floater Rear End, Black or Charcoal Weld Racing Magnum Pro Double Beadlock rims, 28'' x 4.5'' front with 33.5'' x 17'' GoodYear Slicks, Northmead Auto 2-Speed Auto PowerGlide Gearbox, Stage 3 Neal Chance Torque Converter, 16 x Mike Moran 250lb Injectors, Accufab 90mm Throttle Body, Accufab Clamshell Clamps, Hogan's Racing Intake Manifold (different setup to what u normally see manifold wise air comes in at the bottom), Aeroquip Kevlar Hoses, SpeedFlow Shadow series fittings, Aeromotive Fuel Pump & Regulator, Moroso 4-Vane Vacuum Pump, 8 x EGT probes, Dual NTK Lambda Sensors, B&M Stealth Pro Bandit Shifter, 2 x Simpson 10ft chutes. GrooveRyder is putting in some extra bars, doing all the mounting, pipework, radiator, making a custom fuel cell. Motec guru Shane T will be tuning the car and everone is confident of 1700+hp at around 30-35psi on Methanol. hopefully we will run low 7's and working to high 6's. should have it all ready by December.
here is the car he is putting that crazy stuff in
I'm keen as on the flush fitment atm. Too lower offsets are cool don't get me wrong but sitting perfectly flush with a little camber is where its at for me atm
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
