What the hell is that sapphiregraphics?
I know it is meant to be a Lamborghini Murcielago but the transmission tunnel would surely prevent a middle seat a-la the McLaren F1.
car above =
The Predator Extreme is a car with an identity crisis. It does not know whether it is an expensive Italian supercar, a Formula 1 inspired sportscar or a Japanese sedan; because it calls upon touches from all of these. The nose is inspired by the Ferrari Enzo. The bodylines are pure Lamborghini and although the seats look like the Lambo offerings, the seating position is pure McLaren F1. Quite possibly my favorite touch to the exotic looking kit car is the incorporation of the Infiniti G35 taillights. Whoever would have thought that Nissan’s luxury brand would be said amongst the names of Ferrari, Lamborghini and McLaren?
short list of goodies in it
- Top Secret prepped block (oil/water galley etc.) - HKS Step III 2.8 L kit (87 mm x 77.7 mm) - Nismo N1 bearings and seals - HKS IN/EX metal gaskets - Trust extended oil pan and pick up - Trust oil pan baffle plating - HKS Metal Flow air filters (x2) & polished speed density conversion - HKS GT-2835R A/R 0.73 turbine kit (x2) - ARC Pro Class twin entry intercooler - Nismo GT surge tank - Top Secret/NAPREC custom port matched - Custom NAPREC ø49 mm oversized throttles - HKS exhaust manifolds - HKS GT wastegate (x2) - Top Secret Drag front pipes ø 80 mm - HKS Metal Sports ø 75 mm sports catalyser - Trust Ti-R titanium exhaust system 90 mm - Bosh Motorsport 550 fuel pumps (x2) & Nismo in-tank fuel pump - Top Secret fuel collector - Earls custom braided fuel lines & fittings - Sard fuel pressure regulator - Trust Grex fuel rail - Top Secret/Sard 1000 cc/min injectors - Top Secret SPL ported & polished head - HKS 1.2 mm metal head gasket - Tomei head bolts - HKS 272º & 10.5 mm lift (IN/EX) - HKS Limited Edition Valcon V-Cam Pro 16/30 - Tomei valve springs (double) - Tomei titanium valve retainers - Tomei valve seats - Top Secret slide cam pulleys - Top Secret Super timing belt - Blitz Racing 8 spark plugs - Nismo N1 engine mounts - Trust oil pump - Nismo N1 water pump - Yashio Super Race radiator - Sard Type-D thermo - Sard water filler cap - Billion polished power steering fluid tank - Top Secret oil catch tank custom rerouted into intake - HRD 130A High Power alternator - M-spec Nur high power battery and upgraded lines - HKS 15-row oil cooler - Trust oil filter relocation & HKS billet filler cap - Top Secret oil bypass collector tank & Earls lines - Tabata RR Race radiator & HKS cap - Garage Defend carbon radiator shroud - Samco silicone radiator hoses - Robson carbon fan shroud - Robson carbon fuse box cover - Robson carbon spark cover - Top Secret chromed engine covers - HKS F-Con V Pro fueling computer
Transmission:
- ATS twin plate carbon clutch with 1350 kg pressure plate - ATS lightened & balanced flywheel - Nismo Spec III racing clutch operating cylinder - Top Secret Super Release shift fork - Nismo large diameter input shaft - Cusco Type RS rear LSD
Suspension & Brakes:
top-secret-competizi-4_460x0w.jpg - Nitron Pro NTCNIO12R 3-way adjustable racing suspension kit - Cusco adjustable rear upper arms - Top Secret HICAS remover kit - Ikeya Formula front pillow adjuster links - Ikeya Formula front upper links - Ikeya Formula roll center adjuster lower arms kit - Ikeya Formula tie rod ends - Ikeya Formula multi-link spacers - Ikeya Formula adjuster rear lower arms - Ikeya Formula rear camber adjuster bar arms - Ikeya Formula traction adjuster rods - Ikeya Formula rear knuckle pillow bushes - Cusco carbon Pro front strut bar - Brembo 8-pot calipers with 380 mm 2-piee slotted rotors (front) - Brembo 4-pot calipers with 355 mm 2-piece slotted rotors (rear) - Endless CC-R brake pads - Top Secret braided brake lines
Wheels & Tires:
- Spark Silver Volk Racing TE37 19x9.5 +12 (front & rear) - Bridgestone Potenza RE-11 275/30/19 (front & rear)
Exterior:
top-secret-competizi-6_460x0w.jpg - Top Secret custom dark grey blue pearl paint with glass coating - Nismo Z-tune front bumper - Top Secret carbon front diffuser - Nismo Z-tune front fenders - Nismo R-tune carbon vented hood - Top Secret carbon hood dampers - Do-Luck side skirts - Top Secret rear carbon diffuser - Top Secret rear carbon vortex generators - Ganador Super Mirror - Nismo dry carbon rear wing blade - Custom Top Secret carbon wing mounts - Shaved 3rd brake light and lock from trunk lid - Top Secret smoked LED fog lights/reverse lights - Sunline Racing v2 LED lights with LED blinkers - Nismo front & side smoked indicators - Nismo carbon pillar garnish - R35 GT-R front grille emblem - PIAA carbon type wipers
Interior: top-secret-competizi-3_460x0w.jpg - Top Secret custom spot welded chassis - Top Secret/Personal steering wheel with Robson Leather alcantara & blue stitching - RBH boss - Ronson Leather custom carbon/alcantara upholstering - Robson Leather carbon center console & various inserts - Robson Leather alcantara headliner - Nismo Combination Meter - XaNavi Birdview navigation system - Blitz Type-R Dual SBC - Nismo MFD Ver. 2 - HKS Type 1 turbo timer - HKS Variable fan controller - HKS V-Cam controller - NEKO Corporation AF700 A/F meter - Pioneer DEH P919 head unit - Top Secret gear knob - V-spec II pedal set
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
