found a pretty good build on ausrotary (think u need to b a member to see it so ill pop a few goodies here)
here is his photobucket album if u wanna troll
hey all, im building a full tube chassis Ford powered 1991 Dodge Daytona, it will have a 4.6L Ford Mustang Cobra V8, 2 x Garrett GT42R turbo's, 2 x TurboSmart Pro-Gate 50 WasteGates, 2 x TurboSmart Race Port Blow off Valves, Ported Ford Cylinder Heads, Comp Cams, Forged Ford Crasnkshaft, custom Diamond Pistons and custom Manley Rods, Motec M800 ECU, MOTEC CDI, CDI Marine Coils, Mark Williams 40-spline 9.5'' Diff, Mark Williams Carbon Fibre Driveshaft, Romac 4-Link Floater Rear End, Black or Charcoal Weld Racing Magnum Pro Double Beadlock rims, 28'' x 4.5'' front with 33.5'' x 17'' GoodYear Slicks, Northmead Auto 2-Speed Auto PowerGlide Gearbox, Stage 3 Neal Chance Torque Converter, 16 x Mike Moran 250lb Injectors, Accufab 90mm Throttle Body, Accufab Clamshell Clamps, Hogan's Racing Intake Manifold (different setup to what u normally see manifold wise air comes in at the bottom), Aeroquip Kevlar Hoses, SpeedFlow Shadow series fittings, Aeromotive Fuel Pump & Regulator, Moroso 4-Vane Vacuum Pump, 8 x EGT probes, Dual NTK Lambda Sensors, B&M Stealth Pro Bandit Shifter, 2 x Simpson 10ft chutes. GrooveRyder is putting in some extra bars, doing all the mounting, pipework, radiator, making a custom fuel cell. Motec guru Shane T will be tuning the car and everone is confident of 1700+hp at around 30-35psi on Methanol. hopefully we will run low 7's and working to high 6's. should have it all ready by December.
here is the car he is putting that crazy stuff in
I'm keen as on the flush fitment atm. Too lower offsets are cool don't get me wrong but sitting perfectly flush with a little camber is where its at for me atm
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
