Who says 2.5 tonne yank tanks don't fly?
Anything can fly if you hit a ramp hard enough ... I'd like the see it handle the 'Ring though. $20 says it couldn't do a sub-11 min lap without breaking something.
This is a factory "Baja Rally" special edition, $15K worth of suspension upgrades give an extra 115" travel.
going by the reviews ect its no slouch, but given its an off road focused car (not like the trucks like the SRT10 Ram and SVT F150 Lightning)
Then again every review i have read has been done on dirt
Edited by Whiplash
ok so i havent flooded you with Speedhunters for a while, but i had to post this
It is one of many demonstration cars that are kept at the shop and used on a daily basis by the man himself. Like most of the cars that come out of Rocky Auto this Skyline has been given a new breath of life, with a series of modifications that transform it into a very modern feeling car. Power is courtesy of an RB25DE, which is smooth and powerful, allowing the classic Skyline to retain its original straight-six feel.
The interior looks factory enough...
...until you take a closer look. That ignition looks a little too modern doesn't it? That's because it's taken from a C33 Laurel, much like all of the lower section of the dash board, the wiring loom and even the steering mounted stalks.
All four manual windows have been converted to electric-operation by using the motors and commands from a later generation 70's Skyline model.
The car may sit a little high, but it's been set up like that to allow it to clear ramps and other urban obstacles one may encounter.
Behind the Watanabe front wheels are 4-pot Nissan calipers taken from an R32 GT-S typeM. The front suspension arms and linkages have been borrowed from an S13 Silvia while the dampers are from an S14. Rocky Auto always takes great care underneath the car, trying to make the handling more akin to a modern sports car. They certainly know what they are doing!!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
