yeah my chrome fail comment was a little broad
As long as its not a genuine m3, has altezza tail lights but no engine mods and 3 tv's per vehicle occupant, those rims are acceptable..
their those CCW wheels yeah? they look damn good and are pretty cheap too
Last time I priced up a set of CCW classics (when I still have the Celly), I was looking at a little over $6k shipped...
really? on theyre site it says theyre $2500 a set. how much was the shipping?
edit: even if you went the powder coat and arp stud route youd only be adding around $850
Shipping was was an astronomical amount. Somewhere around the $1500 mark. 22lbs a wheel, in customs sizes and specs with upgraded hardware. Though it 'starting at $2500' 3 years ago when I was looking at them.
  • 1 month later...
I am getting so f**king excited about this car and everything it represents. Starting weight of 1180kg for the base model, and 1240kg for the range topper, with the same power as the last locally delivered S15, and all with fuel economy good enough to make it suitable for daily duties... Yeah, I'm pretty keen.
Has been confirmed by Toyota for sale in Australia, and Subaru won't be far behind when they figure out how they're going to market it without their symmetrical all wheel drive safe tag, Tom's and TRD are already looking at warmed up versions, Toyota themselves want owners to modify and personalise theirs. So refreshing.
Non turbo 2.0 litre boxer direct engine with 147kw, STi BRZ may be turbo, 6 speed manual, or 6 speed paddle shifted auto, LSD, rear wheel drive, and all in a 1200kg package.
As for price, Toyota is aiming for the low $30k range.
Yeah according to Speedhunters, they have already released info to the Nippon Aftermarket Committee so manufacturers and tuners can start production of aftermarket parts! New car owners will have the option to change out the suspension and add aero mods on day 1 of ownership!
THIS!!! What a revolution. Best thing a car company has done in a long time.
Cant believe Nissan tried their darndest to exclude the GTR from the aftermarket scene, why not encourage personalisation and stimulate the aftermarket economy!
In short, the car gives me a hard on. Looks wise, not so much, but the potential.... huge.
I'm a big fan of the way they look.
That second photo I posted shows a couple more or less confirmed options for when it goes on sale in North America/Europe, fixed back seats, harnesses, and TRD gauges.
It's something I would never have expected from Toyota, openly embracing the aftermarket. I imagine the options list will be pretty immense by the time it hits dealer floors here.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
