Hi guys,
Just wondering if anyone could give me some advice. I installed a head unit tonight and couldn't seem to get the drivers side speakers to work (unsure if they ever worked though but I was pretty sure they did).
Also I am having problems with my dash light as well, it seems to have died just wondering if the head unit is in any way linked to the dash not lighting up and is there is some type of weird setup for the front speakers.
If you guys have any info on this it would be much appreciated.
Thank you,
Aaron :(
Edited by offroadaaron
youve wired the power to the illumination circuit . prolly find your tail lights arent going either . get a 1.5 volt battery and touch it on the two wires that you think are for said speaker . should hear a click/pop when you connect it
Arrrrhhh yes the tail lights are out.
Thank you.
ok so left speakers were easy but I had H plugged in for a ground (earth) which on the diagram is says not to do. all the Other wises look correct from what a can see on this diagram.
All the wires are different colours for the nissan side but they seem to match up location wise.
PS. having H plugged into earth worked. Is this the illumination cable?
