Wondering if anyone else has this problem and what they did to fix it?
Basically when starting the engine from cold it takes about a minute or 2 before the thermostat opens.
During that time the engine feels really rough, when pushing the accelerator the engine starts to stutter when going beyond a certain rev range, until the thermostat opens (ie the temp gauge starts to move). Then it is fine.
It doesn't really bother me too much as it helps me warm up the car slowly.
Car is R32GTR with apexi pods and catack exhaust+cam gears.
I've also started to notice that it pings as well until the thermostat opens.
Is there something going on I need to fix quickly?
https://www.sau.com.au/forums/topic/272491-engine-feels-resticted-when-cold/
my 33gtst is the same. when its cold if i accelerate too hard it sounds like its going ok but is jumping around like its gonna blow up. i am guessing that my old mechanic put the wrong oil in cause it kinda feels like the pistons arent moving smoothly. i am possibly completely off but just my guess.
This is a factory feature of the ECU to protect your motor when it is cold.
Until you have reached the expected operating temp it places a number of restrictions on the level of advance of the timing and other paramaters to stop you from working the engine too hard while it is cold.
If it runs well when it has warmed up then all is good as it is only doing what it was designed to do - it does become a problem though if it does not run crisp after it has warmed up and that is when there is something wrong that needs investigation and fixing.
You should just let your car warm up a bit anyway just before driving (On cold mornings).
I usually let it idle for about 2-3mins to get the engine oil circulating then start driving and keeping it off boost for about 5-10 mins of driving (light boost is ok) to get all other fluids going.
Then the car is fine.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
