they look pretty similar in dimensions. the sock of the GT-t pump is slightly different.
it is as close to a direct fit as you could get for a different pump although i haven't done one.
if it isn't a direct fit it would be some pretty simple minor mods to make it fit.
Edited by wolverine
they are for similar hp cars so if follows that they are going to have similar flow rates.
i wouldn't use a GT-t as an upgrade considering there are so many reasonably priced aftermarket pumps out there but as a direct replacement or as a cheap lift pump it would be ok.
Gtt pump is the same size as a walbro and a walbro is a direct fit if your game, we retrofit 040's or JZA80 pumps. The R33 uses a bosch / GTR size pump that is larger than the r34 GTT
Edited by URAS
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
