I run a Competition Steel Hatted Os Giken Twin Plate in my R32 GTR TS2CD
Heavier on the pedal than most about a 7 out of 10
Plate rattle is quiet in comparison 3 out of 10
Clutch Grab is a positive and awesome 10 out of 10
pedal feel is excellent and driveable in traffic 6 out of 10
replacement plates (rebuild kits) 5 out of 10 (cost bit over half of new clutch)
Durability of Clutch 10 out of 10 (this clutch has seen, im sure over 1000 launches)
Tell us a bit about yours so others can determine what they would like to buy in the future
My hope is to work out whether to rebuild my clutch or go new
Thanks everyone in Advance :(
https://www.sau.com.au/forums/topic/272501-gtr-twin-plate-clutches/
No-One use Twin Plates?
they are only mandatory for GTRs
:P:D:mad:
Pffft why? There's two types of people that use twin plates, those who need them because their making big power (400kw+) and those that don't like their gearbox's :D Well thats what I seem to see over and over again anyway :D
I have the OS TS2CD twin plate an absolutely love it, easy to drive good in traffic not to heavy that is, good bite and enough play so that you dont feel like you have a brass button in or out oh my god i hated those.
Great for launches for those that know how to do it properly without leaving your driveline on the floor behind you :down: and believe me some drivers are brutal. I will definately keep this or replace unless i chase more power and its out of its limit.
Os Giken make quality parts and i like to know that i have good parts in my car you pay for what you get.
TS2CD, bought it as it was cheaper second hand than anything else i could have got for 30det, awd.
a little bit of slip, enough to drive it reasonably in traffic. yet enough bite to side step it with a few revs on.
pretty noisy tho, like a couple of dinner plates in the tumble drier. if you know what the noise is its not a worry tho.
Pffft why? There's two types of people that use twin plates, those who need them because their making big power (400kw+) and those that don't like their gearbox's :( Well thats what I seem to see over and over again anyway :)
Really dont get your Reply!
What do you have in your GTR?
What Power output?
and Pffft WHy? Where should i Start why!
any way tell us what you run so all can make their own mind up
The pfft why was in regards to your 'twin plates being mandatory for gtr's' comment. I don't understand why people put crazy clutches in cars that don't require them, it's cheaper to smash a clutch than it is a gearbox, the clutch should be able to hold maybe 10% more power than what the car is making otherwise it's just overkill, thats my opinion anyway.
My car makes about 300kw and i'm using a stock clutch with no issues, car is used mostly for weekend outings and track......
Nismo coppermix competition model (740 PS or something like that)
Very easy to drive, isnt noisy has never slipped. Wouldnt even bother looking at any other clutch... Im too happy with this one!
Seen the power rating for the 2009 model? Finally its getting closer to what the HKS GTRS guys need :)
This is a bit of a funny thread.
Sure singles do the job, but there's just something about the way twins work in GTR's that makes you think they should come standard.
Launching time after time, hard changes, positive feeling on changes etc - SO good!
I regret selling my nismo twin, have an os giken triple plate currently, as soon as nismo increase the c spec twin to handle 800hp ill be back with one of them.
Cant compare os giken to nismo, sure they both feel good by themselves, if you dont believe me, do a test back to back. Nismo will win.
With that said there's also some quick GTR's on tricked up singles.
End of the day, its personal preference, and out of all the GTR owners i know, only 3 have single's. :)
I'm probably still on the stock single! Are you suggesting that I change to twin? Hearing so much about launching makes me want to do it but after starting at around 4000 or 5000rpm once and getting the burnt smell after kinda put me off from doing it ever again until I'm sure it's safe to do it.
im using a NPC billet twin plate.... very light clutch pedal, quiet rattle and easy pickup 10/10 in my opinion!
im using the same...NPC billet is the mother of all clutches...properly set-up to each cars requirements is the way to go when buying a clutch. Im not a fan of out of the box, one size fits all clutches. Even a properly set-up custom single plate will out perform most of the multi plate off the shelf offerings.
Dont bother launching on the stock clutch :D
Hi Guys, im new to this forum,
Ive just bought a GTR last week with supposibly 330 RWKW and a Os giken twin plate.
I think it has more like 280rwkw and the clutch is screwed.
It slips really badly and is on its way out shortly.
What clutch should i get, keeping in mind i only drive the car on the weekend and maybe ill try a track day.
I obviously dont need a twin plate again, How much do you need to spend to hold say 310rwkw?
89 gtr push type
thanks
^ same, orc 709d. When new it was a right bitch to get going, unless using a generous serving of rev's and a rapid release.. now it is very nice but with a decent bite. Seems to handle everything I have thrown at it so far, and I'm not real kind. Jangles like everything is stuffed with the clutch in, makes a funky noise on cranking.. all part of the character.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
