NPC twin plate, engagement is smooth (unlike os giken etc), pedal is pretty easy, definately daily driver material and only about $2050 from memory. Handles 600awhp (rev limiter drag launches) on my 1750kg car no drama and would definately reccomend them.
The best part is they are only about $300-$400 to rebuild, where as os giken etc are like $1200 etc to rebuild.
That's a definite plus; and is worth considering. I think I got about 40k km out of my OS including various trackdays etc. before it needed a rebuild.
I guess rebuild cost should be considered along with longevity and the other factors.
My twin plate is massive, its bigger than the os giken quad plate i had before.
... which isn't surprising :) Quad plates means you don't need so much diameter to get the same amount of contact area...
Cheers,
SW
Howdy Matt
Bolts were supplied with the Clutch so no probs there yeah around 5mm shorter
Since the original post ive since removed the clutch and found that some grease had came out of the spigot bush and contaminated the flywheel to friction plate ,Sooo
once it goes back in id say any shudder would again be minimal or eliminated (grease cleaned up and machined off) , still a light pedal and close to standard operation , though still launches hard and positively as the clutch should
i still have a high grab point (grabs around the last quarter travel of the clutch pedal ) some say thats normal yours being a 33 and pull type will be quite different
where does yours grab close to floor or close to steering wheel?
So far I have only driven a HKS Twin Plate.
Heavier on the pedal than most about... Was not that heavy.
Plate rattle is quiet in comparison... Was loud, almost a "tearing" sound.
Clutch Grab is a positive and awesome 10 out of 10... Yes it was awesome!
Pedal feel is excellent and driveable in traffic... Was a pain in the ass, if you get lazy / tired, not much play, it was either in or out.
Replacement plates (rebuild kits) 5 out of 10 (cost bit over half of new clutch)... I bought the Nissan OEM R32 GTR Single Plate.
Durability of Clutch... Previous owner would have most probably gave it hard, it lasted me about 2 years of ownership till replacing it with OEM clutch.
A very good clutch for drag / circuit just to slam it in and out, a lot of grab and launched the car quite fast.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
