  • Replies 54
Posted Images
I'm looking forward to seeing this! Only 2 weeks now =P Still a bit intrigued that your NEO had the blanking bolt as opposed to a blank spot where a oil feed would go. I thought it was the non-NEO DE's that had the blanking bolt.
yeh it suprised me as well lol
mod list:
turbonetics stage 2 t3 turbo (450hp)
turbosmart ultragate 38mm
emu
gtt injectors
33 gtr pump
adj sard reg
adj exh cam gear
3" turboback
fmic
hoping for 200+
nice list, i have always liked their gt-k series with the black front housing.
but 1 thing im wondering... why choose a turbo that needs an external gate for now? if your aiming for 200-300rwkw, you could do that easily without an external gate...
how much psi u hoping to put in?
12psi atm.
i picked up this turbo for same price as a stock rb turbo and its a heap better turbo so i figure why not get it, has plenty of power left for future buildup if i choose to go down that path as well.
oh and ext gate sounds awesome!
12psi atm.
well if it was that cheap then why not!
but wot about the manifold tho? with manifold, turbo and gate id imagine you could get a internally gated aftermarket turbo for the same price? or was this setup alot cheaper?
im only para because of the popo in melb... might not be as bad for u....
and yes.. external gates sound pretty bloody nice.
The biggest issue is if you use the stock ECU and a piggy-back, counter-tuning the stock timing is a little time consuming.
If you keep the compression high, the best thing to do is get a larger than stock sized turbo if you want to run pressure over 9psi, flowing the exhaust gasses out as quick as possible is better to stave of detonation. I've seen T04E's on these engines spool like stock from the higher energy combustion that you get from high-comp.
The fitment is pretty easy, can be done at home over a weekend with no real dramas.
When you say spool like stock..? I've never had the joy of driving a factory turbo..
So you wouldn't recommend running more than 7PSI for a factory R33 GTSt Turbo? I'm still running 7 PSI of the actuator, eventually planning to get a EBC, possibly a Gizzmo as they seem to be very reliable and excellent value for money. So perhaps it's best to have a larger turbo before running more than 7 to keep some sort of reliability?
haha yeah I just mean come on boost earlier, some turbos get a good 1000rpm earlier boost than if they were on a 9:1 engine, nice :laugh:
You can run more than 7psi, just you may need to lose some timing in order to do it...and it may be one of those things were the gain of boost ends up not netting much extra in power. A turbo with a bigger rear housing will make more use of the extra gas flow and as a result you can run more boost as the heat is getting out of the combustion chambers quicker.
the 33 GTST stock turbos are reliable at 10-12PSI afais. mainly on RB20s as there isnt as much stress on them as they dont spool up as quick as on the 25s. its when you go to 14 that you start having reliability issues.
Dan, are you saying having a larger dump/front pipe reduces detonation? (makes sense really when i think about it)
From the way I understand it, you want to get the gas out of the engine quickly. Too small a turbo and it will become a restriction to flow. Just like say an old factory cat converter in a high powered car, except that after the manifold, the turbo is the first place hot air ends up after it leaves the engine.
I would imagine that the front/dump pipe should be a size that allows the air to flow and scavenge optimally. Too big and you reduce the efficiency of the exhaust system. Would I be right in my thinking by saying that changing to a larger front/dump pipe but not touching the turbo would be like fitting a larger catback system, but not changing a restrictive cat? If a front and dump is able to flow enough for the given amount of power (lets say 3" for the average N/A+t), but the turbo isn't able to pass through the exhaust gasses quickly, then the restriction isn't the front/dump and changing to a larger front/dump isn't going to make much of a difference.
The goal would be to get the exhaust gasses out of the engine and out of the turbo quickly, therefore making power and more of it, efficiently, and lowering the time that hot air stays in the engine and turbo, therefore reducing chances of detonation.
Please correct me if I'm wrong
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
