Fm Expander
This is going to be a real forehead slapper when it is solved
Am installing a FM expander to a 01 V35 300GT with bose stereo.
For some reason can't get it to work. Expander is an Aerpro (AP745)
and have both diversity antenna adaptors AP348A
and AP348B
ok so i have connected the factory antenna to AP348A - the male fitting of AP348A to the female of the fm expander - the male of the fm expander to the female of AP348B - connected AP348B to the stereo.
Alas no FM signal - Am works wonderfully though.
What have i done wrong
Oh and the fm expander is wired to the cigarette lighter if anyone is wondering.
Will post pics if anyone wants them.
ok -
OEM antenna->AP348A->AP745->AP348B->OEM radio.
power the band expander up off the light green wire in the radio harness.
that works as thats how I do them daily.
Hey guys
Thanks for the reply chris
So it seems i have connected the components in the right order - it is hard to get it wrong the problem must be faulty expander.
This is an item you sell Chris ever had a faulty expander?
I might test it in my other car - for example if itune the radio to 85.3 it should be 105.3?
Cheers
I do sell them. never really had a dud one though.
do you have it in the right way?
I see you are in brissy. run it past when you haev a sec.
Cheers chris
probably come down sat need to talk to you about cruise control
can't believe a car could come with leather seats xenon headlights premium sound and no cruise control - what a gip
  • 1 year later...
and AP348B
Have you tried wiring it to a continuous live wire instead of the cigarette lighter which tends to be ignition controlled. Wiring to the lighter would mean its only working with the ignition on
 Share
    • This is untested by me, however, its one of the weird but well known behaviours of polarisation and Quantum Physics, and may be able to be used here. A simple way to check if sunglasses are polarised, is to take a pair of sunglasses you know are polarised, then hold the pair you want to test so that the lenses are at 90 deg, and when you look through the two lenses, it will be black. However, if you take a third pair and hold them at 45 deg and between the pair, looking through all three lenses will be almost clear. Weird, but supposedly true and it depends on the weird behaviours caused by quantum effects.
    • I'll leave this here Owned it for 5 days, changed alignment and its .7 of a second slower than my 180sx up Noosa hill climb. Mca reds, cusco diff and short ratio, e85, some gktech arms, endless pads and Nankang CRS Tyres.  I beat a gt3 porsche with an experienced targa driver too.
    • Sometimes Japanese rust is stronger than Chineesium steel...
    • AAAaaaaarrrrrrggggghhhhh! Following on from OP's AC woes....mine got regassed last year and at some point I discovered it had lost enough gas to not switch on any more. It had dye in it, but we never saw any trace of dye, perhaps because it all fell out long enough before we looked that it washed away. (Or, shudder, it's under the dash in a hard to see/reach spot!). I almost never run the AC because I just drive with the windows down even when it's 40+ outside. Only occasionally want it when I just can't take the heat or if I need some defog. So, got it gassed up again with more dye and oil so I could run it a bit to provoke the leak to show. And the compressor is noisy. So, now I am staring down the barrel of having to fit a rebuild kit to the compressor (or maybe the spare that is on the shelf).  And hope that the leak is at the comp, and not under the bloody dash.
