Oil Catch Can *NEW*
Hi,
Here's the pics.
http://www.geocities.com/sil21jun/OilCatchCan.html
Here are some dimension:
Barrel length : 15.5cm
Barrel diameter : 10cm
Filter diameter : 5cm
Length from bracket to filter : 18cm
Side hose piping: 3cm each
I hope this gives you a rough idea if your engine bay is jam packed with other performance gears. I test mount this on my S13 and the bracket bolt nicely to the CDI/boost solenoid mounting. This will be located on the passenger side on the strut wall. I hope I have not confused you too much. It can be place anywhere you like but at the expense of a longer hose.
Price is $110 COD at your cost.
 Share
