Got the Sh%#$ with the crap laying around in the shed and spare room, so I went nuts taking pics and want to get rid of the stuff.
Pretty much all this stuff is just make an offer or free. I've got prices in mind for some things, but I'll see what happends.
Stock R33 GTS-t intercooler
http://home.iprimus.com.au/jayson77/parts/cooler.jpg
Stock R33 GTS-t dump + front pipe + heat shield.
Also front pipe piece (pretty dodgy) no back flange - for free !
http://home.iprimus.com.au/jayson77/parts/exh.jpg
Stock R33 GTS-t clutch fan + fan + shroud (shroud has had the top cut slightly) - clutch fan and fan SOLD
Stock paper filter for R33 GTS-t airbox. Only done about 3000km.
http://home.iprimus.com.au/jayson77/parts/filter.jpg
Standard R33 GTS-t Cat converter. Works fine, not clogged etc. - SOLD
Front brake pads for R33 GTS-t – pretty sure they are stock ones. Heaps of meat left on them.
http://home.iprimus.com.au/jayson77/parts/pads.jpg
Interior light from R33 GTS-t. Has slight crack in it.
http://home.iprimus.com.au/jayson77/parts/light.jpg
Misc suspension bits for stock suspension on a R33 GTS-t
http://home.iprimus.com.au/jayson77/parts/susp.jpg
http://home.iprimus.com.au/jayson77/parts/susp1.jpg
90 degree 2 1/2 inch rubber bend. One clap fits it, the other is a bit small. SOLD
Twin air horns - SOLD
2 gold fuse holders, one of is mountable, comes with one 60amp fuse and a few metres of cable.
http://home.iprimus.com.au/jayson77/parts/cable.jpg
27mhz President Adams CB. 40ch, AM SSB, modified for extra power, 7khz slide (moves between channels !).
Pearce-Simpson Cub, 40ch AM only.
SWR + Matcher for 27mhz. Handle upto 100w.
http://home.iprimus.com.au/jayson77/parts/cb.jpg
Electrophone 27mhz CB – probably good for parts (if your keen !)
http://home.iprimus.com.au/jayson77/parts/cb1.jpg
27mhz SWR meter
http://home.iprimus.com.au/jayson77/parts/cb2.jpg
Ultrasonic (or microwave??) module for Moss Alarm. If your good you could modify it to suit different alarms.
http://home.iprimus.com.au/jayson77/parts/ms712.jpg
Spot light – 750,000 candle power !! great for spot light shooting, or blinding the fools that refuse to dip their lights !! - SOLD
Rear (or front! Can’t remember) Lovell sway bar for a Datsun 180b !!! Don’t laugh ! Never used….
http://home.iprimus.com.au/jayson77/parts/sway.jpg
MISC stuff below….
Kenwood home graphic (old).
http://home.iprimus.com.au/jayson77/parts/graphic.jpg
Desktop charger for Nokia 8250. Ear piece for 8250. And never used Nokia 3210 covers.
http://home.iprimus.com.au/jayson77/parts/phone.jpg
Spear gun, double band, two heads - Back for sale
Video sender – sends about 5-10 meters at the most !
http://home.iprimus.com.au/jayson77/parts/video.jpg
¾ yard glass !! used once at 21st. Still has all the packaging…
http://home.iprimus.com.au/jayson77/parts/yard.jpg
Happy to send interstate if REALLY keen !!
J
https://www.sau.com.au/forums/topic/27254-fs-make-an-offer/
White 32 - yepp, the bend will slip straight onto a 2 1/2 inch pipe. The inside diameter of the bend is 64mm. Just note that one clamp fits it, but the other is too small, but I'll throw in both.
No problems about sending it to you COD, can send off Monday lunch time.
Make an offer for it :(
J
https://www.sau.com.au/forums/topic/27254-fs-make-an-offer/#findComment-573757
  • 1 month later...
  • 1 year later...
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
