My boyfriend import this car from Japan for me from his friend so we know full history of the car is in excellent condition I want to sell it since I am going Overseas..
No accident history, serviced, well maintained. I spend lots of money on that car music system is worth $3000, wheels $2000, suspension $4000, exhaust $1400 but the engine wasn’t boosted so its in great condition. Want to sell it for reasonable price. If you have any questions or offer please don’t hesitate to email me at: [email protected] or call 0420903535
NEW FULL SUSPENSION $4000
CUSTOM MADE EXHAUST $1400
CHROME AND BAYSIDE BLUE ENGINE $1500
TARANTULLA AND ROCKFORD SOUND SYSTEM WITH SONY DVD PLAYER $ 3000 +INSTALL
19` WHEELS (RUBBER MIGHT NEED REPLACING)
TURBO TIMER WITH AUTO ALARM
BOOST CONTROL- I HAVE NEVER USE IT AS IM A TYPICAL WOMAN DRIVER..
NISMO FRONT BAR
U MORE THAN WELCOME TO COME AND HAVE A LOOK AT THE CAR
I THOUGHT CAR WILL BE SOLD TO MY FRIEND BUT SHE HAD AN ACCIDENT A WEEK AGO THATS WHY I DID THIS LISTING 3 WEEKS B4 MY TRIP
CAR LAST TIME WAS DRIVEN A MONTH AGO AS I HAVE A SCOOTER AND THE OTHER CAR FOR DAILY USE... SERVICE HAS BEEN DONE 2 WEEKS AGO .BEFORE THAT EVERY 3 MONTHS OR 4OOO KM`S.
https://www.sau.com.au/forums/topic/272565-r34-gtt-4-door/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
