Parked neutral or in gear?
52 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I personally leave my cans :ninja: in neutral. The only time I leave it in gear is on a steep incline, and that's once in a blue moon.
So the can does not roll down the hill.... haha
When I drive a manual car - i've been told to always leave it in 3rd gear or higher, never knew the real reason for 3rd specifically... but I'm *guessing* if you leave it in first or second and you accidentally crank the engine in gear you could possibly cause the car to literally start moving.
in an auto car - I always put it in park when the car is parked.
I think the majority would leave it in Neutral, as most would have a turbo timer installed (on this site). but when i drive a car without i would leave it in reverse as i have heard its the strongest gear.
Hay guys me again when ur parked should u leave ur can in gear or in neutral ?
What gear if u should leave ur car in if left in gear ?
What do you do, do u leave ur car in neutral or in gear ?
Thanks for your answers guys
When i was learning to drive many moons ago,like 30 years i was told to park in first gear in a manual and park in auto,don't know if it's right but it's worked for me so far. :ninja:
Probably what some dumbass's logic was, for leaving it in a high gear. You will definitely move if you crank it in a low gear.
The reason for parking it in a low gear ie 1st gear is that 1st provides the greatest resistance to moving. 4th gear will roll freely, 1st will stop a car.
If you're on a really steep hill then reverse is normally a bit shorter still so use it instead.
Personally I always park on flat ground so I leave it in neutral. If I park it on a steep driveway then I leave it in gear.
I live down a steep hill and park my cars on the street, i always parked with 1st gear in and it has saved me many times.
I once went to drive to work one morning and obviously didnt pull the handbrake up tight enough jumped in pushed the clutch in and the car started to roll down, HOLY COW 1st gear managed to hold 1.5 ton of car all night from rolling down the hill into one of my neighbours lounge room.
For me now its habit living down a steep hill for the last 20 years and many times this has been the case where the gear saves a handbrake in need of tensioning etc etc.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
