cm712 Posted May 31, 2009 Share Posted May 31, 2009 Hay guys me again when ur parked should u leave ur can in gear or in neutral ? What gear if u should leave ur car in if left in gear ? What do you do, do u leave ur car in neutral or in gear ? Thanks for your answers guys Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/ Share on other sites More sharing options...
alanz Posted May 31, 2009 Share Posted May 31, 2009 id say put the can in the bin. =) Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4627858 Share on other sites More sharing options...
2LV8ETR Posted May 31, 2009 Share Posted May 31, 2009 I personally leave my cans in neutral. The only time I leave it in gear is on a steep incline, and that's once in a blue moon. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4627941 Share on other sites More sharing options...
iseekool Posted May 31, 2009 Share Posted May 31, 2009 I personally leave my cans in neutral. The only time I leave it in gear is on a steep incline, and that's once in a blue moon. So the can does not roll down the hill.... haha When I drive a manual car - i've been told to always leave it in 3rd gear or higher, never knew the real reason for 3rd specifically... but I'm *guessing* if you leave it in first or second and you accidentally crank the engine in gear you could possibly cause the car to literally start moving. in an auto car - I always put it in park when the car is parked. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628027 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted May 31, 2009 Share Posted May 31, 2009 i have a manual with remote start...... Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628115 Share on other sites More sharing options...
astrotristan Posted May 31, 2009 Share Posted May 31, 2009 i have a manual with remote start...... woah playa faw real! im a neutral dude Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628141 Share on other sites More sharing options...
GT-5732 Posted May 31, 2009 Share Posted May 31, 2009 I think the majority would leave it in Neutral, as most would have a turbo timer installed (on this site). but when i drive a car without i would leave it in reverse as i have heard its the strongest gear. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628160 Share on other sites More sharing options...
Humbla Posted May 31, 2009 Share Posted May 31, 2009 Hay guys me again when ur parked should u leave ur can in gear or in neutral ?What gear if u should leave ur car in if left in gear ? What do you do, do u leave ur car in neutral or in gear ? Thanks for your answers guys When i was learning to drive many moons ago,like 30 years i was told to park in first gear in a manual and park in auto,don't know if it's right but it's worked for me so far. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628165 Share on other sites More sharing options...
blind_elk Posted May 31, 2009 Share Posted May 31, 2009 Always park with gearbox in 1st, handbrake ON (obviously), even if it's auto. Sometimes put it in reverse if parked downhill, but usually 1st. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628293 Share on other sites More sharing options...
Zurlox Posted June 1, 2009 Share Posted June 1, 2009 Usually in neutral, but if on a hill/incline reverse cos if someone runs up the arse it will only destroy reverse gear and you still have the full forward range Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628409 Share on other sites More sharing options...
cm712 Posted June 1, 2009 Author Share Posted June 1, 2009 Hahaha "can" yeah ill edit it .. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4628504 Share on other sites More sharing options...
Kinks Posted June 1, 2009 Share Posted June 1, 2009 i've been told to always leave it in 3rd gear or higher, never knew the real reason for 3rd specifically... but I'm *guessing* if you leave it in first or second and you accidentally crank the engine in gear you could possibly cause the car to literally start moving. Probably what some dumbass's logic was, for leaving it in a high gear. You will definitely move if you crank it in a low gear. The reason for parking it in a low gear ie 1st gear is that 1st provides the greatest resistance to moving. 4th gear will roll freely, 1st will stop a car. If you're on a really steep hill then reverse is normally a bit shorter still so use it instead. Personally I always park on flat ground so I leave it in neutral. If I park it on a steep driveway then I leave it in gear. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4629472 Share on other sites More sharing options...
Basti Posted June 1, 2009 Share Posted June 1, 2009 Always park with gearbox in 1st, handbrake ON (obviously), even if it's auto. Sometimes put it in reverse if parked downhill, but usually 1st. most autos wont let you take the key out unless its in park Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4629496 Share on other sites More sharing options...
bozodos Posted June 1, 2009 Share Posted June 1, 2009 in neutral most of the time due to turbo timer, in 1st in any other car (always catches me out when i do park my car in 1st and forget to clutch it when starting hahaha) Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4629892 Share on other sites More sharing options...
Mr GTR-32 Posted June 5, 2009 Share Posted June 5, 2009 I live down a steep hill and park my cars on the street, i always parked with 1st gear in and it has saved me many times. I once went to drive to work one morning and obviously didnt pull the handbrake up tight enough jumped in pushed the clutch in and the car started to roll down, HOLY COW 1st gear managed to hold 1.5 ton of car all night from rolling down the hill into one of my neighbours lounge room. For me now its habit living down a steep hill for the last 20 years and many times this has been the case where the gear saves a handbrake in need of tensioning etc etc. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4639339 Share on other sites More sharing options...
Silver_GT Posted June 5, 2009 Share Posted June 5, 2009 Car facing down hill; reverse, car facing up hill; first thats my habbit, seems the most logical to me so i stuck with it Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4639437 Share on other sites More sharing options...
Evos33 Posted June 5, 2009 Share Posted June 5, 2009 I always leave my car in neutral because of turbo timer. Link to comment https://www.sau.com.au/forums/topic/272582-when-parked-neutral-or-in-gear/#findComment-4639477 Share on other sites More sharing options...
