Hey all,
I have some RB26 engine parts from a 32GTR that I'm selling. So if your interested in any of the gear below send us a pm!
ALL PARTS LOCATED IN ADELAIDE AND AM WILLING TO SHIP @ BUYERS EXPENSE
-34 Intake plenum $100
-intake manifold assay(injector plate) $400
-Throttle bodies + linkages $350
-Injectors + fuel rail + reg $250
-Rocker covers + front cover + valley cover $400 (painted in red)
-Front cover backing plate + vac lines $50
-R32/33/34 wiring loom $450
-Head ( with cams, cam gears, valves, lifters etc) $1200
-R32 Crank $300
-Crank girdle + crank scraper $150
-Block (has some scuff marks from ring land failure) $200
-2WD gtr sump conversion $300
-Power steering bracket $20
-Crank pulley X2 $50 each
-coil packs $150
-Oil filter assay(water cooled) $150
-Turbos( the pair, with dumps, exh manifolds etc) $500 the pair
-oil/water lines for turbos $100
-AAC valve + vaccuum lines $200
-Air regulator(for idle control) $100
-Throttle valve switch $80
-R33 centre grill $100
-R33 Front bar (N1 look-a-like) $200
-Twin turbo connecting pipe X2 $30 each
-Stock exhaust manifolds $50 the pair
-CAS (cam angle sensor) + backing bracket $200
-Alternator $80
th_rb26parts027.jpgth_rb26parts028.jpgth_rb26parts033.jpgth_05302009106.jpgth_05302009105.jpgth_05302009097.jpgth_05302009096.jpgth_05302009102.jpgth_05302009095.jpgth_05302009094.jpgth_05302009074.jpgth_05302009073.jpgth_05302009075.jpgth_05302009076.jpgth_05302009078.jpgth_05302009079.jpgth_05302009081.jpgth_05302009083.jpgth_05302009084.jpgth_05302009085.jpgth_05302009086.jpgth_05302009087.jpgth_05302009092.jpgth_05302009091.jpgth_05302009090.jpgth_05302009088.jpgth_05302009103.jpgth_05302009100.jpgth_05302009101.jpgth_05302009099.jpg
https://www.sau.com.au/forums/topic/272590-rb26-engine-parts/
  • Replies 46
Hey buddy,
What condition are the injectors in? If all good ill prob take em.
Also do you have the dropping resistors for the injectors?
Cheers
Edited by Sports Crazy
Hey all. If you need a part atleast make a serious offer and no low balling!!!
Send us a pm for any of the remaining parts!!
ill pay full price for the block and crank if the girdle is supplied for free.
Tried to send PM but your inbox was full! Will sell you the complete package comprising of Block, Crank, Crank girdle, mains caps,
mains studs and crank scraper for $700 (the $200 is for postage - due to the size and weight of the package I have to have it
couriered to you) If you like this offer send me a PM and we can organise payment and delivery!
Edited by huli
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
