I have tinkered with my Stag and brought the boost up 3psi by bypassing the bleed solenoid. The car ran great for a few day but has now seemed to have learnt it has no control over the boost level and fuel cuts my fun.
Has anyone worked out how to bypass this??? I noticed there is a boost sensor in adition to the MAF.....I figure I could bleed off air to the MAP but the MAF would still read the same.....
https://www.sau.com.au/forums/topic/272609-m35-stagea-boost-cut/
I don't know how your boost cut works. Apparently on the R34 there is a sensor which cuts boost that can be fooled by a resistor in the circuit (its somewhere here on this site) but I don't know about your v6. I gues it depends on your long term plans. With the range of cars that you have i guess this is not going to be your drag car so you won't want to fork out for a Vipec ecu. I would suggest you build a DFA or buy a SAFC and fit that to give your engine some tunability.
It Fuel cuts, It seems to learn that it can't control boost. If i use snow mode its ok for a while then cuts again. How have you installed your boost controller?
All I have done so far is removed the std high-low valve. gives High boost all the time. instead of retarding it in low RPM.
did you unplug it? or leave it plugged in?
try the opposite of what you have now. i remember some nissans have a sook if you left them plugged in, or not plugged in when it wasnt being used..... might be worth a try!
In my car i have a apexi boost controller that controls the boost levels and i left the existing boost solenoid plugged in electrically but blocked off all the hoses.
  • 1 year later...
i know its a while back.
but did it make any difference?
If you loop off the boost solenoid and then run the line from the intake in to the suction pipe it will allow the boost level to build a lot higher.
Cheers
Andy
Cheers
Andy
Potentially catastrophic levels.. Id get a decent (read, doesn't max out at 15 or 20 psi) boost gauge to ensure youre not making too much if you do bypass the boost solenoid
With an Impul, yes... but not so with the Stock ECU.
If I loop the solenoid line and bypass it with the intake line, I max out at 1bar (where I hit the cut) whereas if I leave it plumbed as per stock, I hit around 1.3bar or so before cut
Edited by iamhe77
if youre taking the factory solenoid out of the equasion and have the boost line from the intake going down to the wastegate actuator, then youre running whatever the actuator is set at. if you remove the pipe to the actuator completely, then youre running whatever the turbo can do. ie, the wastegate will probably not open at all! dangerous for more than just your turbo.
just go EBC and make sure youre exactly where you want to be.
If you remove the pipe to the actuator completely, then youre running whatever the turbo can do. ie, the wastegate will probably not open at all! dangerous for more than just your turbo.
Only if the restrictor is removed from the solenoid line.
if there is no air going to the actuator due to the lack of vacuum pipe going to it, then it wont matter where the restrictor is :)
however, the restrictor is the first mod that should be done to all turbo cars :D
yeh mine seems to climb to about 16-17psi before hitting cut. i dont know if its when i did the BB conversion, apparently the turbo guy likes to put washers on the Actuator flap to hold boost a little better..
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
