righto bit of an update td06 kit back up for sale as buyer pulled out
so anyway for 1900 you get the manifold turbo oil line wastegate all heat wrapped
removed cause i wanted a bigger tubo and gtsr manifold
perfect working order and will bolt up to a rb25/20/2530
was on car and running perfectly , no smoke ect was happy for test drives
buyer put money down and was happy to take it so it was removed
buyer turned up and said that it had too much forward and backward movement(approximately 2 mm)...
on the car with oil pressure there is no play
car ran perfect and im happy for buyer to speak to mechanic who removed it that can confirm the turbo kit is a ok
so its up for sale again
grab yourslef a bargain
1900 the whole kit
https://www.sau.com.au/forums/topic/272621-td06-20g-turbo-kit-1900/
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
