Quick question guys......
Is it normal for rb26 to be so rich on idle?
It sits anywhere from 11.6 to 12.5 on idle once the engine is up to temp.
Thought it was a little strange so i checked it out on another 26 what do ya know.... same thing!
These two 26 however are not in its "original" gtr chassis, so i just wanted to confirm if a original gtr behaves the same,or if there might be a problem with the wiring when it was transplanted.
Both are R33 engines running stock ECUs, 3" exhaust, 12-14psi, one with walbro pump,one with bosch, intake pods and using 95 fuel.
The car pulls very good ,no misfiring or hesitating, although i find the idle is a little lumpy and it uses a lot of fuel and my rear gets a little black soot after a while.
Is this normal?
https://www.sau.com.au/forums/topic/272627-rb26-afr/
OK some more info.....
Hooked up a pfc out of the box (UNTUNED) and got the following
With the ign on O2 (1) 0.04v
With the ign on O2 (2) 4.56v
On idle O2 (1) fluctuating between 0.04v - 0.88v
On idle O2 (2) constant at 0.12v
AFR at 12.5
At 1600 rpm O2 (1) constant at 0.92v
At 1600 rpm O2 (2) constant at 0.14v
AFR at 10.8 and couldn't rev any higher because it was starting to break up.
Also tested and got a 12v for the heater supply at the two sensors.
So i guess O2 (2) is screwed?!?
And why O2 (1) is only cycling at idle, and not when revved to 1600rpm
What do u guys think?
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4633361
Not sure what u mean???
you can switch off the 02 feedback to the ECU.
go into etc and function select and change the 02 option. if you are unsure look at the power fc faq.
or you can call me on skype or something and i can explain
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4633511
I installed my new wideband setup in my R34 and ran it around for a few weeks with the car 100% standard so I could get a picture in my head of how they japs tune them from factory.
Idle is 14.6-15.1:1 when warming up and when up to temperature. Idle stability when cold is achieved by idling faster, not richer.
It ran 13:1ish on mild boost too up to about 0.4 bar or so, and only got to 12:1 at full boost (0.8 bar). It dipped into the mid 11's toward the top end of the rev range at full load as well.
I have an FC in the car now. The load points around idle are at about 0.985 or something... That produces a 14.6:1 idle AFR. Check your temp corrections if this is way out, and as suggested turn off O2 feedback. It probably wont make any diference, but who knows the fuzzy programing logic that goes on inside these ecu's...
With my previous gtr and the tune I ran in it, I only ever turn that on after the car is tuned. And even then it was probably correcting very little. It only really comes into play when driving up hills to improve my fuel economy as at light load level ground cruising i'd run 16:1 @ 60km/h and 15.5:1 up to 100km/h. Above that its 14.7 at any sustained level ground speed.
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4634379
Ok i understand now.
But what difference should it make to tell me if the sensor is bad, being that the pfc is running on its base map?
Turning them both off will stop them referring to the O2 - what good is it having them looking to a dead O2 for a reading? Its no good.
Hence turn them off and watch what happens :laugh:
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4634515
Hence turn them off and watch what happens ;)
well i hooked up the pfc again today switched off the feedback control and nothing happened!
Afr remained the same and the O2 voltage (1&2) remained the same.
Also with it on or off O2(1) kept constant at 0.84v where as yesterday it was cycling between 0.04-0.88v
I pulled out the vac line for the brake booster thus creating an air leak so the wide band went lean and while peddling the throttle it was cycling the afr from rich to lean and the voltage on the O2(1) sensor bounced between 0.0-0.98v which seems up to scratch.
O2(2) however remained at 0.0-0.2v
I know there must be a few stock gtrs well with pfc installed.
Could some one just run outside, and check their hand controller and tell me what the voltage reads for the O2 sensors when the car is now started and after warming up. :D
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4635872
With closed loop off the idle afr regardless of what it is should be stable. Lets assume you have a 14.7:1 afr at idle, that should be 0.5v on the narrow band. The factory sensors have a very narrow operating band where 0.45-0.65 is the only usable voltage range where the afr can be read accurately. The limits of the sensors range is 0v = lean and 1v = rich.
Yesterday when you saw it cycling it was the computer operating in closed loop mode trying to hunt around the 14.7:1 afr of 0.5v. It will stay on the rich side of things with the o2 feedback turned off.
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4636643
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
