Rb26 Afr
Thats the problem.
It stays rich with it on or off, it does not make a difference.
As far as i can tell o2(1) is ok
I would just like to know if o2(2) is supposed to cycle as well or remain constant.
Thanks.
Ah... sorry i misunderstood. No they are both supposed to change. You definatly have a dead 2nd o2 sensor.
Some widebands setups output a simulated narrowband output too. You might be able to wire that to the ecu instead of replacing your dead sensor.
I use the AEM uego wideband which i think has the output but i'm using the stock ecu. I only hooked up the pfc to read the O2 voltages (borrowed from a friend).
One other thing i noticed was when i gave it a quick rev to 2000rpm the air flow voltages will go up to about the same amount but AF2 will drop off before AF1, and will go to about 0.2v and then climb back to meet AF2 at about 0.9v where two of them remain steady.
The two air flows are clean and i am using the stock air box at the moment.
Could some one else give me their opinion on the O2(2) sensor remaining constant? And which one the pfc takes as the O2(2) sensor the front or the back?
Thanks again.
Yea already have that info. thanks anyways.
I also noticed from the manual the front o2 sensor suppose to cycle between 0-1v and the rear in P or N range 0v and other than P or N range 4-5v
So i guess i should be looking for a voltage fluctuation between 4-5v ????
Well changed th o2 sensor today using a rb25det sensor, it was a direct plug in for the rear sensor on r33 rb26 just the wire on the sensor is shorter so i had to reroute the harness...no biggie though.
Anyway my ratios now look as they should- Idle at 14.7-15.3 an when i hold it at 2000rpm it cycles between 14.7- 15.7
So i guess i would be looking forward to some improved fuel economy :D
Thanks for all the help guys
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
