Just to clarify, the RB26 and RB25 fuel rails all bolt up to the GReddy RB25 intake manifold. The difference is the injectors / FPR. I need to clarify as im doing a 25/30 using a greddy manifold and just need to open up my options for fuel rail, injectors and fpr.
Many thanks.
You will need a set (of 6) alloy injector collars to fit top feed injectors to the Greddy/copy inlet manifold, check out the "for sale" section of this forum, there is a guy who sells them for a reasonable cost.
Modifying Rochester injector plugs is easy, just trim off a couple of tabs with a Stanley knife and the Nissan plugs fit straight on. I have a picture somewhere, if I can find it I will post it up. I have a set of 1000 cc Rochesters in the RB31DET, for $77 each I didn't mind spending a couple of minutes each trimming the plugs.
I am in the process of testing 13 different types of JECS injectors (dont ask me where i got them from) i work in the automotive industry. these are all side feed and are the right impeadence for r32 and r33 gtst ecu's
RB20's come with top feed injectors standard.
Cheers
Gary
I know SK, :banana: they come with red top 270cc top feed. but if you are building a 30det based on a 33 head and you want a remapable ecu you end up with a bit of a bastardized combination like I have
r32, rb25 na vct head, rb30 block, rb20 loom, sensors, ecu, side feed rb25 injectors :)
Cheers
Gary
SK
do you happen to have a pic of the GTR rail and injectors on the Greddy copy plemum?
Any chance you've got a part number or a picture of the Rochester injectors? or is there only one type of 1000cc Rochester injector?
They look like this, there is only one type
And I buy them from http://www.tuffcarparts.com/
Cheers
Gary
so on that website that would be the 96lb injectors. never thought about getting these. much cheaper than anything else i'v seen.
96 lbs per hour = 1000 cc per minute (close enough anyway)
Cheers
Gary
My 1000cc Rochester injectors arrived yesterday and I've sent them off to be flow tested (just a little concerned about the lack of packaging, each injector was in a small ziplock bag with all 6 just throw loose into a postbag).
tuffcarparts is where I got them from, probably are alright but getting them flowtested anyway so I can hand my tuner known numbers and also so I can stagger them so highest flowing is at the back as I'm going to forward facing plenum.
Any 14mm fuel rail should be fine yeah? found an RB20 14mm rail on tweakit that I think is going to be the go.
Edited by bubba
The rail is like AU$240 I think, twin entry to suit 14mm o-rings and RB20 manifold.
I have a custom plenum with RB20 runners and seeing as no-one answered my question about RB26 rails onto RB20 runners, I kept looking for an RB20 specific item.
  • 1 month later...
I figured I would just post in an existing topic instead of creating a new one.
What are peoples opinions on hiflowed stock injectors? Are they safe & reliable and comparable to Sards for example?
Seems nice to be able to save a few hundred bucks on a direct-fitment item too.
Personally i wouldnt go with highflow stock injectors. Prefer to get something that you know wont cause you any problems.
Ive considered this and with many people opinions bought Nismo 740cc injectors instead. Least i know they wont f**k up on me.
Cheers
Gary
If it isn't to much trouble could you please post up a pic of the trimming of the plug.
Thanks
  • 3 weeks later...
Quick question: if I upgraded from the stock 370cc ones to 650cc would it be drivable to the tuner to have the ECU chipped with them in?
Nope - keep your old ones in and swap them at the tuners. It's fairly easy thing to do.
Sweet, one more quick question - does anyone know exactly which Subaru injectors can drop right in?
Is it just the V5 440cc Yellow ones? Heard you can just put em in and turn the plug around the other way and they are sweet?
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
