hey all
iv got a mate whos not a member... i dont know why hes not, WHAT AN IDIOT!!! lol
anyways his problem is
hes got an r34 gtt 2door
while hes driving anywhere... usually above 60km/h, all the electrics shut off and the engine dies,
till he comes to a stop...wait a few minutes and then starts up again perfectly fine....wierd
hes taken the car to a local mechanic and aparently it requires a "hot/ cold sensor".....worth $900 from Japan
now...... iv never heard of this. im a 3rd year app mechanic n iv asked many friends at work... no idea
any help? is my mate getting stooged?
cheers
https://www.sau.com.au/forums/topic/272718-random-shutdown/
my mate had a similar issue with his ceffy after he put in his rb25 and didn't have the dash connected up. there must be a resistor in the dash (or somewhere between the ecu and the speedo sender) that reduces the voltage as my mates ecu was hitting the speed limiter. but i don't think it was actually shutting down.
maybe there is an issue with the AFM that is putting it into limp more. i would suggest getting a consult cable for about $60 and check the ecu for fault codes. the electrics shouldn't shut off if it is simply a leaking bov, etc.
actually i hust had a really funny thought. if it is happening at a regular interval, it could be his turbo timer if he has one. there could either be a fault in the ignition wiring that is making it think the ignition has been turned off, the turbo timer may be faulty, or the turbo timer may be wired up incorrectly.
https://www.sau.com.au/forums/topic/272718-random-shutdown/#findComment-4630851
i just remembered that a mates 33 i put a emanage ultimate into had a dodgy harness and when bumped it would just die completely and nothing would work. it was like it had a flat battery. just had to push the harness into the ecu's nice and firmly and it was fine.
https://www.sau.com.au/forums/topic/272718-random-shutdown/#findComment-4630872
hot/cold sensor is very non-specific.
are there any errors showing on the ECU? try plugging in a PFC and going to sensor check. Since its a 34 I'm going to guess it will be showing THRO error which is for the little map sensor at the rear of the plenum. The sensor itself is pretty reliable but the loom it it often fails - therefore $900 from jp would not help.....
https://www.sau.com.au/forums/topic/272718-random-shutdown/#findComment-4641863
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
