Calder October 10, 2003
NIZPRO BA XR6 TURBO LETS LOOSE with an 11.73 At 125.90 mph.
Nizpro debuted their Acid Rush BA XR6 Turbo sedan at Calder Raceway on October 10, 2003 intent on some ‘shake down’ passes, noting that Nizpro staff were specifically interested in data logging to ensure that whatever changes that may be required, could be easily implemented in the future.
Vehicle modifications consist of Nizpro’s Stage One XRT300 power-up kit (custom powder coated high-flow CNC machined inlet manifold, cast alloy thermostat housing, powder coated cast alloy rocker cover, cast alloy 100mm inlet tube, K&N pod filter, cold air-box, high-flow tube and fin intercooler with lightweight aluminium end tanks, compact dry-cell Odyssey battery and battery box), along with upgraded fuel injectors, and a MoTeC M800 ECU.
For a 4-litre Ford engine that is surprisingly close to stock internally to deliver a potent 426 kilowatts through the wheels on a DynoLogic chassis dynamometer, Nizpro had also to replace the restrictive catalytic converter (in an otherwise factory exhaust system), along with a high-flow fuel pump replacing the factory item.
245mm wide Nitto road/race tyres were also fitted to an otherwise stock vehicle (including the factory turbocharger) that weighed in at 3918 pounds at an independent weight station.
Traction proved a problem, as did the diff ratio that resulted in the Falcon hitting the factory imposed 5700rpm rev limiter by Calder’s 1100-foot mark. However the Nizpro team were quite happy with the information provided by the data logging, and also drove away happy with the knowledge that they had just set the fastest ever time for a BA Falcon Turbo with a respectable 11.73 @ 125.90 mph.
Nizpro’s Simon Gishus stated that having established a base line, and become aware of all potential problems, that he will make specific modifications to ensure the vehicle meets or at least goes close to meeting its potential at the next outing.
Using the traditional Drag Racing formula (speed over mass over distance), it showed that wheel spin and hitting the rev limit had resulted in a loss of approximately 3-4 mph off the terminal speed, with the top end charge indicative of a run perfect 10.6 second pass.
Note: Further information on Nizpro’s Acid Rush sedan, their heavily improved BA XR6 Ute, or on any of the Nizpro XR6 Turbo power up kits; Contact Nizpro on 03-9761 1522.
https://www.sau.com.au/forums/topic/27273-nizpro-xr6t-into-the-11s/
Its good to see that that car is able to make that sort of power with that little development thus far.
Its alos interesting to note that the underated gearbox has lived and shows it potential. it will just be interesting to see just how long it will live.....
If i see an XR6T come at auctions that has been rear ended, then i can see a FORD powered 240Z sitting in my driveway.
Nizpro do good work, friends 200SX engine setup is courtesy fo them and it definitley performs.
Im assuming it was an auto... its scary the potential of some company cars
Awesome!!!
Was only a matter of time before someone put an XR6T into the 11s! Congrats to Nizpro.
Was just reading before in the latest ZOOM that they have their XR6T up to 260rwkw with way more to go.
APS have theirs up to 511hp@fly and SHV have theirs at 400kw at the flywheel..... impressive figures.
This is what separates the Japanese sports cars with the Aussie built performance cars. The Ford XR6 Turbo "Barra" project was undertaken with a very small budget in the hope to boost (no pun intended) some showroom sales against the popular Commodore SS's....
...and this shows, no money was spent on the R&D for a stronger driveline. Ford are STILL using Borg Warner hardware. A T5 manual gearbox, BTR auto's and weak BW 2 pinion diffs. It's great to see that people like Chiptorque, Nizpro, CAPA and others are making impressive numbers on both the dyno and track by defeating the ECU's abuse/protection modes, but it's a shame the weak drivelines let these cars down.
Hahaha. SHV. Shit-House Vehicles. Don't believe a word they say. Driven their purple ute and it's a pile of shit. An NA R32 GTS-t running on 3 cylinders would flog it and that's before you get to the woeful interior quality, horse-and-cart ride, non-existent brakes, etc etc
Originally posted by Sonic
An SP20. It's a daily driver for insurance purposes as a 1966 Skyline ain't the most comfy car to trundle freeways in (damn no air con, p/steer, etc). Seeing as the Skyline bit the dust, the Mazda is also doubling as weekend play-thing
LOL that the car my gfriend has!!
when u gonna own a real car?? :)
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
