My priorities for ading to the car have now changed a bit (no more personalised plates for me), and it looks like next cab off the rank is the front bumper/spoiler whatever you want to call it.
Since it looks kinda Naff to just do the front spoiler without side and rear bits I'm thinking import monster might now get my cash for the whole kit. These are my first options:
#1:
Pro: cheap, looks pretty good.
Con: needs painting, is it a straight DIY fit? It says it only goes on 2004+ and mines a 2002??
#2
Pro: looks great
Con: only the front part
https://www.sau.com.au/forums/topic/272737-best-aero-kit-for-the-m35/
  • Replies 42
The Gialla one looks like you would be driving around with a park bench on the front of the car... good for watching the kids play footy maybe, but thats about it...
+2 for the dolphin front end it is awsome.. I also had the same question about it when i saw it on IM... get the whole kit including the grill insert... make molds!!! :ermm:
dolphin prices
FRONT BUMPER SPOILER 税込 \75,600 (本体価格\72,000)
SIDE STEP 税込 \63,000 (本体価格\60,000)
REAR BUMPER SPOILER 税込 \71,400 (本体価格\68,000)
FRONT GRILLE 税込 \31,500 (本体価格\30,000)
so about 3500 then freight...
#1:
#2
Pro: looks great
Dunno which kit #1 is (perhaps save image, upload into photobucket, post PB link), but #2 would look odd with the NM35 headlights.
If it fits a PM35, i will fit an NM35.
Kid's Heart R35 set-up? :P
If only, hey?
Got BIG $$$$$?
LOTS of 2nd hand ones on IM
Where? I regard myself as an advanced web user and have been buying tech on yahoo (real site) for years but i can never find s#*t on IM! I like factory aero.
do you browse and go through the whole 80 pages or what?!
Edited by Houdini
Man f**k using IM, just use the yahoo website and google translate it if you need be
http://translate.google.com.au/translate?u...en&ie=UTF-8
or if translation fails translate this link..
http://list1.auctions.yahoo.co.jp/jp/26318-category.html
click thru till your in the catagory, usually for aero i will go PARTS/EXTERIOR AERO/NISSAN and then search m35 or whatever..
usually IM wont come up with as much as the searching is a bit different
is there a simple way to get it into import monster once I've found it through normal yahoo?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
