My priorities for ading to the car have now changed a bit (no more personalised plates for me), and it looks like next cab off the rank is the front bumper/spoiler whatever you want to call it.
Since it looks kinda Naff to just do the front spoiler without side and rear bits I'm thinking import monster might now get my cash for the whole kit. These are my first options:
#1:
Pro: cheap, looks pretty good.
Con: needs painting, is it a straight DIY fit? It says it only goes on 2004+ and mines a 2002??
#2
Pro: looks great
Con: only the front part
https://www.sau.com.au/forums/topic/272737-best-aero-kit-for-the-m35/
  • Replies 42
The Gialla one looks like you would be driving around with a park bench on the front of the car... good for watching the kids play footy maybe, but thats about it...
+2 for the dolphin front end it is awsome.. I also had the same question about it when i saw it on IM... get the whole kit including the grill insert... make molds!!! :ermm:
dolphin prices
FRONT BUMPER SPOILER 税込 \75,600 (本体価格\72,000)
SIDE STEP 税込 \63,000 (本体価格\60,000)
REAR BUMPER SPOILER 税込 \71,400 (本体価格\68,000)
FRONT GRILLE 税込 \31,500 (本体価格\30,000)
so about 3500 then freight...
#1:
#2
Pro: looks great
Dunno which kit #1 is (perhaps save image, upload into photobucket, post PB link), but #2 would look odd with the NM35 headlights.
If it fits a PM35, i will fit an NM35.
Kid's Heart R35 set-up? :P
If only, hey?
Got BIG $$$$$?
LOTS of 2nd hand ones on IM
Where? I regard myself as an advanced web user and have been buying tech on yahoo (real site) for years but i can never find s#*t on IM! I like factory aero.
do you browse and go through the whole 80 pages or what?!
Edited by Houdini
Man f**k using IM, just use the yahoo website and google translate it if you need be
http://translate.google.com.au/translate?u...en&ie=UTF-8
or if translation fails translate this link..
http://list1.auctions.yahoo.co.jp/jp/26318-category.html
click thru till your in the catagory, usually for aero i will go PARTS/EXTERIOR AERO/NISSAN and then search m35 or whatever..
usually IM wont come up with as much as the searching is a bit different
is there a simple way to get it into import monster once I've found it through normal yahoo?
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
