ready to chuck a 12" sub in. had this for ages but never used it. was hidden in a cupboard in my house and forgot it was there. use to have a kenwood 12" sub but nothing now just the box. sealed box.
nice and small.
good condition.
take it away now! don't need it as i've been over car audio for ages now.
Edited by jakez88
https://www.sau.com.au/forums/topic/272742-12-kenwood-sub-box-20/
