  • Replies 55
^^ Hmm. In my case all the internal stuff was out of a almost brand new Series 3 box which had 11,000 KMS on it. It was purchased in may/ june 2006 from Just Jap. You would think that I would have the lastest revision in my box at the moment. and I cant see it being worn that much after so little work to require a new one.
Your right mate, you should have the latest synchro setup. You gotta ask yourself, is it really that bad you want to pull the box down ? Maybe your a harsh shifter ? has it been like this since day one with the OS ?
Since the first time i drove it. It doesnt matter if i shift hard or not as it is there under power in 3rd gear only. After smashing a box im the biggest fairy with shifting!
I got a call from a bloke in England who has exactly the same issue at exactly the same speed. He has done 12,000 kms on his box and has run a high 10 @ 135 ish MPH, so making a fraction more grunt then me. He hasnt broken it yet, so i might just put up with it. Only time will tell.
  • 3 years later...
hi paul,
i just came across this thread - 4yr thread bump :)
how is your box holding up & that 3rd gear vibration?
is anyone else still having 3rd gear vibration symptoms & any subsequent updates since?
Well while the car was apart I had it pulled down and rebuilt. The vibration is still there, but no where near as bad as what it was. When the new rear diff goes in illl be putting in solid alloy bushes. See is that has any effect on it.
Did u end up changing any parts during the rebuild or balance any of shafts?
This intrigues me and I'll explain why. My mechanic changed my clutch and as soon as this was done, 3rd gear vibration became apparent under load and boost. With the old clutch, it was perfect.
I called Terry @ Award Diff and explained the symptoms my car was having and he bluntly said "its your spigot bush" which makes perfect sense to me as it was obviously damaged during the r&r (before I changed my clutch, there was no vibration). He explained it is something to do with 3rd gear running on the same shaft / input shaft. I can't remember the exact explanation BUT he was adamant and this is why the issue is there only in 3rd gear...under load 3rd gear vibrates due to loose tolerance between input shaft and spigot.
Have u replaced your spigot?
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
