i sent the rest of my payment this morning as id like to get that out of the way and start focusing on the cars needs. probably be in by Tuesday next week.
crap i didnt read this post
krishy - when i have received everyone's deposit by June 25, we will send out the registration form (word or pdf document) so that you can send your details and the $285 balance of payment directly to John Bowe Driving.
when you receive can you just foward it on for me cos its already sent :D
  • Replies 383
when you receive can you just foward it on for me cos its already sent :rofl:
no problem at all. it cleared into the account on Saturday. i'll forward it on to John Bowe Driving, but i will need your details to complete their registration form - i'll PM when i need them. cheers
tomorrow is your last day to secure a place on this intro trackday course
you don't have to have a mega horsepower, stripped out racer with massive brakes and a roll-cage to do this course. far from it - all you need is a mechanically sound car with normal tires & brakes, and the desire to learn something new. you don't even need a helmet with this particular course.
whats with the metal caps? only thing i have noticed about them is good looks and annoying for when checking tire pressure :O
supposedly they reduce the chance of pressure loss if the tire sidewall is hit (like sideways onto a curb) whereas the plastic caps can/will crack & fall off. they also recommend that you run higher tire pressures for street tires on the track to stiffen the side walls (eg 38psi+ cold for a 17" street tire).
these are John Bowe Driving's recommendations, not mine - people can debate with the instructors directly if they want to.
Inline 6 has expressed his interest in going on this day - thanks for taking the last spot! I will send you the PM with all the details tonight.
everyone else - i will PM/email the official JB enrolment form out tonight/this weekend
i'm sending the official enrolment form via PM now, but have encountered an interesting problem with this forum - i can only send individual PM's every 5 minutes or so. unless someone can tell me how to PM a list of people at once, this will take me a while...
yeah, unfortunately they put in pm restrictions thanks to some spammers a couple months back. stupid. i know. youre stuck doin it the hard way.
that sucks. this is going to take me a while then :D
PM sent your way as you're near the top of Heslo's list.
Send me the documents Kim, I think I can send more than one every 5 mins :D
have cc'd you to the one i sent scandyflick.
can you send it and the attachment to the following members? :
Joshdc
Moodles2
Luke ENR34
Hostile
typevu
Krishy
Red Back
32godzilla
chalon
i will send a slightly different enrolment form to Ripp3r as he has paid the full amount already. Inline6 has indicated his interest in the event - i have PM'd him the deposit details so am waiting to hear back from him this week.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
