You obviously have never been in a properly set up Supra for circuit racing.
I was being rather sarcastic.....have seen some mad supras on tracks
Hey Krishy, I will take some shots for ya while your in action!!
Thanks for that martin.....looking forward to it woot woot
  • Replies 383
Hey George, are you taking your Supra to this? Have you finished all the mods (turbo, manifolds etc) on your car now?
Looks like my car will be stuck in RWD with no ABS so I'll be the guy facing the wrong way each corner and having everyone take evasive action around me.
The new G sensor which my car needs costs about $3000. F**ken GTRs! :thumbsup:
jeez man buy one from a wrecker... screw a new one
-D
Gtr's run as a RWD anyway unless ur under full load. The GTR behaves like a rear wheel drive car and is very tail happy as we found out with mine and a certain V8 500 driver last week at Mallala. So you have to be correcting yourself the Attessa can only do so much and we were drifting and correcting nearly every corner and you can feel the correction with the application of front wheel drive but it still has no effect when your pushing the car beyojnd its limits and you still have to rely on your own driver skill to negotiate the turns.
yeah but he's got a fwd daily :P no chance lolz
i have no abs either, shell be right steady foot works best :P
^^ and its not quite full load or 100% rwd, watch the dial when you put ur foot down, itll go to about 10% fw torque. theres usually something going to the front but in the end 32s still feel pretty much like a rwd on most bends
Edited by Inline 6
Picked up the car from Manta yesterday and despite the G sensor indicate red and failing the diagnostic test it now has 4WD & ABS :huh:
Funnily enough when we put it on the dyno today at HiTech it didn't want to come out of 4WD despite the fuse being pulled and the Field torque split controller being unplugged. The new BlitZ EBC and oil lines to the GReddy catch can will hopefully be sorted on Thursday and I think I'll fit the Recaro race seat for the day. Fingers crossed all goes well.
Now I'm just debating whether to buy a helmet before the 25th? I know it's not mandatory but with my driving history and luck...
as the course is set up as an introduction to track days, we won't be going flat out 100% to maintain safety and also to minimise the cost to the drivers (recognising that not everyone wants to invest in a helmet if they haven't decided on whether they're going to do regular trackdays yet) but it's up to you if you want to bring one along on the day.
so I'm not familiar with how much the wear and tear will be on my car so heres what ive done.
-new tread all round
-new coolant
-mobile 2000 10W-40 oil and filter change
Do i need to have new brakes? if so whats good brakes? no green or red stuff ideas tho(too expensive) just chuck me good brand an what id have to pay for 2 pairs. i got some dot4 factory line racing brake fluid for when i put new pads in.
anything else i may need?
I'd keep your tyre pressure's at at least 30 psi, if its a cold day or raining you wont get enought heat in your tyres and you'll just slide around or roll the tyres of the rims. Take a tyre pressure guage with you and when you start to push the car hard for a few laps then check the pressure, try to keep it about 30-36psi. I doubt you guys will see much of a pressure increase as this couse is only a beginer thing and you wont have helmets so i doubt you'll be able to push your cars very hard.
actually, the instructors recommend that you start with 42-45psi with street tires to stiffen the side walls for cornering - this is Item 1 of your pre-trackday checklist that is part of the course receipt that Dean from John Bowe Driving has emailed ALL of you going.
this also prevents the tire rolling on the rim with hard cornering, but i suspect that many of you have stretched profile tires anyway :)
i would start with minimum 38psi cold (17"-18" street tires) before you leave home as it will probably rise to 40+ by the time you reach Mallala. it is better to have over inflated tires rather than under inflated as you can always let excess pressure out there (unless you have a portable compressor or pump with you). and dstroy is right - your tire temps won't increase a lot if it is a cold/wet day.
for semi slicks, you would start with 28-30psi cold as these can increase to 34-36psi when hot (after hard cornering, acceleration and braking). you would adjust the pressure for these tires in between laps based on the tire wear across the tread face (need edge to edge wear).
Edited by V35-2005
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
