You obviously have never been in a properly set up Supra for circuit racing.
I was being rather sarcastic.....have seen some mad supras on tracks
Hey Krishy, I will take some shots for ya while your in action!!
Thanks for that martin.....looking forward to it woot woot
  • Replies 383
Hey George, are you taking your Supra to this? Have you finished all the mods (turbo, manifolds etc) on your car now?
Looks like my car will be stuck in RWD with no ABS so I'll be the guy facing the wrong way each corner and having everyone take evasive action around me.
The new G sensor which my car needs costs about $3000. F**ken GTRs! :thumbsup:
jeez man buy one from a wrecker... screw a new one
-D
Gtr's run as a RWD anyway unless ur under full load. The GTR behaves like a rear wheel drive car and is very tail happy as we found out with mine and a certain V8 500 driver last week at Mallala. So you have to be correcting yourself the Attessa can only do so much and we were drifting and correcting nearly every corner and you can feel the correction with the application of front wheel drive but it still has no effect when your pushing the car beyojnd its limits and you still have to rely on your own driver skill to negotiate the turns.
yeah but he's got a fwd daily :P no chance lolz
i have no abs either, shell be right steady foot works best :P
^^ and its not quite full load or 100% rwd, watch the dial when you put ur foot down, itll go to about 10% fw torque. theres usually something going to the front but in the end 32s still feel pretty much like a rwd on most bends
Edited by Inline 6
Picked up the car from Manta yesterday and despite the G sensor indicate red and failing the diagnostic test it now has 4WD & ABS :huh:
Funnily enough when we put it on the dyno today at HiTech it didn't want to come out of 4WD despite the fuse being pulled and the Field torque split controller being unplugged. The new BlitZ EBC and oil lines to the GReddy catch can will hopefully be sorted on Thursday and I think I'll fit the Recaro race seat for the day. Fingers crossed all goes well.
Now I'm just debating whether to buy a helmet before the 25th? I know it's not mandatory but with my driving history and luck...
as the course is set up as an introduction to track days, we won't be going flat out 100% to maintain safety and also to minimise the cost to the drivers (recognising that not everyone wants to invest in a helmet if they haven't decided on whether they're going to do regular trackdays yet) but it's up to you if you want to bring one along on the day.
so I'm not familiar with how much the wear and tear will be on my car so heres what ive done.
-new tread all round
-new coolant
-mobile 2000 10W-40 oil and filter change
Do i need to have new brakes? if so whats good brakes? no green or red stuff ideas tho(too expensive) just chuck me good brand an what id have to pay for 2 pairs. i got some dot4 factory line racing brake fluid for when i put new pads in.
anything else i may need?
I'd keep your tyre pressure's at at least 30 psi, if its a cold day or raining you wont get enought heat in your tyres and you'll just slide around or roll the tyres of the rims. Take a tyre pressure guage with you and when you start to push the car hard for a few laps then check the pressure, try to keep it about 30-36psi. I doubt you guys will see much of a pressure increase as this couse is only a beginer thing and you wont have helmets so i doubt you'll be able to push your cars very hard.
actually, the instructors recommend that you start with 42-45psi with street tires to stiffen the side walls for cornering - this is Item 1 of your pre-trackday checklist that is part of the course receipt that Dean from John Bowe Driving has emailed ALL of you going.
this also prevents the tire rolling on the rim with hard cornering, but i suspect that many of you have stretched profile tires anyway :)
i would start with minimum 38psi cold (17"-18" street tires) before you leave home as it will probably rise to 40+ by the time you reach Mallala. it is better to have over inflated tires rather than under inflated as you can always let excess pressure out there (unless you have a portable compressor or pump with you). and dstroy is right - your tire temps won't increase a lot if it is a cold/wet day.
for semi slicks, you would start with 28-30psi cold as these can increase to 34-36psi when hot (after hard cornering, acceleration and braking). you would adjust the pressure for these tires in between laps based on the tire wear across the tread face (need edge to edge wear).
Edited by V35-2005
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
