You obviously have never been in a properly set up Supra for circuit racing.
I was being rather sarcastic.....have seen some mad supras on tracks
Hey Krishy, I will take some shots for ya while your in action!!
Thanks for that martin.....looking forward to it woot woot
  • Replies 383
Hey George, are you taking your Supra to this? Have you finished all the mods (turbo, manifolds etc) on your car now?
Looks like my car will be stuck in RWD with no ABS so I'll be the guy facing the wrong way each corner and having everyone take evasive action around me.
The new G sensor which my car needs costs about $3000. F**ken GTRs! :thumbsup:
jeez man buy one from a wrecker... screw a new one
-D
Gtr's run as a RWD anyway unless ur under full load. The GTR behaves like a rear wheel drive car and is very tail happy as we found out with mine and a certain V8 500 driver last week at Mallala. So you have to be correcting yourself the Attessa can only do so much and we were drifting and correcting nearly every corner and you can feel the correction with the application of front wheel drive but it still has no effect when your pushing the car beyojnd its limits and you still have to rely on your own driver skill to negotiate the turns.
yeah but he's got a fwd daily :P no chance lolz
i have no abs either, shell be right steady foot works best :P
^^ and its not quite full load or 100% rwd, watch the dial when you put ur foot down, itll go to about 10% fw torque. theres usually something going to the front but in the end 32s still feel pretty much like a rwd on most bends
Edited by Inline 6
Picked up the car from Manta yesterday and despite the G sensor indicate red and failing the diagnostic test it now has 4WD & ABS :huh:
Funnily enough when we put it on the dyno today at HiTech it didn't want to come out of 4WD despite the fuse being pulled and the Field torque split controller being unplugged. The new BlitZ EBC and oil lines to the GReddy catch can will hopefully be sorted on Thursday and I think I'll fit the Recaro race seat for the day. Fingers crossed all goes well.
Now I'm just debating whether to buy a helmet before the 25th? I know it's not mandatory but with my driving history and luck...
as the course is set up as an introduction to track days, we won't be going flat out 100% to maintain safety and also to minimise the cost to the drivers (recognising that not everyone wants to invest in a helmet if they haven't decided on whether they're going to do regular trackdays yet) but it's up to you if you want to bring one along on the day.
so I'm not familiar with how much the wear and tear will be on my car so heres what ive done.
-new tread all round
-new coolant
-mobile 2000 10W-40 oil and filter change
Do i need to have new brakes? if so whats good brakes? no green or red stuff ideas tho(too expensive) just chuck me good brand an what id have to pay for 2 pairs. i got some dot4 factory line racing brake fluid for when i put new pads in.
anything else i may need?
I'd keep your tyre pressure's at at least 30 psi, if its a cold day or raining you wont get enought heat in your tyres and you'll just slide around or roll the tyres of the rims. Take a tyre pressure guage with you and when you start to push the car hard for a few laps then check the pressure, try to keep it about 30-36psi. I doubt you guys will see much of a pressure increase as this couse is only a beginer thing and you wont have helmets so i doubt you'll be able to push your cars very hard.
actually, the instructors recommend that you start with 42-45psi with street tires to stiffen the side walls for cornering - this is Item 1 of your pre-trackday checklist that is part of the course receipt that Dean from John Bowe Driving has emailed ALL of you going.
this also prevents the tire rolling on the rim with hard cornering, but i suspect that many of you have stretched profile tires anyway :)
i would start with minimum 38psi cold (17"-18" street tires) before you leave home as it will probably rise to 40+ by the time you reach Mallala. it is better to have over inflated tires rather than under inflated as you can always let excess pressure out there (unless you have a portable compressor or pump with you). and dstroy is right - your tire temps won't increase a lot if it is a cold/wet day.
for semi slicks, you would start with 28-30psi cold as these can increase to 34-36psi when hot (after hard cornering, acceleration and braking). you would adjust the pressure for these tires in between laps based on the tire wear across the tread face (need edge to edge wear).
Edited by V35-2005
    • Also, the cause of fuel spills and smells from the top of the tank is almost always the rubber hoses that are up there, not the tank seal.
    • 1. No, as you say you can remove the connectors and fuel lines. Before you do make sure you remove fuel pump fuse and crank the starter a few times to release pressure, and also loosen the fuel cap (just in case the tank is slightly pressurised) as it will pump out the lines otherwise 2. Not necessary but you are right, if it is the factory pump it is at risk of failing after 25 years....Changing it is not hard but potentially not trivial as you have to make sure you have the right pickup/sock for the pump to suit the tank, need to make wiring connections (crimped butt connectors would be fine) and have to mount/adapt the new pump in the right place in the cradle. Not impossible but don't start the job if you aren't confident. Also, the plastic nut that holds that seal in place can be really hard to remove. If you don't have a fuel nut removal tool it generally requires a big screwdriver or similar to bash the ring around a few times before you can get it by hand. Also the fuel lines can be very sticky on the tank lid fittings, hose removal pliers can help or if not twist the hose on the fitting (eg with linesperson's pliers) to break the seal before you try and remove it. Finally, mark the feed and return hoses so you don't put them on backwards and seal them with an m8 bolt to stop crap getting into the lines while working. Add a little grease in the threads of the plastic lid when you go to do it back up as a gift to your future self, and make sure you put it on evenly/not cross threaded.  Having said all that, most likely the lid just needs to be either tightened or removed and put back on without being cross threaded...the seal itself is usually pretty good.
    • Another weekend and another project I have questions about.... I bought a fuel tank sender O ring to install on the car because I'm quite sus on what I've got now.  1. No "whooosh" sound when opening fuel cap 2. If I fill up full tank, there will be a small leak under the car and it comes from the top of the fuel tank, dripping along the side. Stops after a short while 3. Hot days = 50/50 chance to get high as a kite inside the cabin if the car was in the sun for too long This is what I bought: https://www.amayama.com/en/part/nissan/1734279900 My plan was to just replace the O ring but I've got some questions: 1. Does the whole fuel pump assembly need to come out for me to replace the O ring?         Or, could I unplug all the connectors and fuel lines at the top, take off the twisty part (17343) and put in the O ring from the top?  2. Is it a very common thing for everyone to just change the pump whenever doing this?        I see the Walbro 255 gets thrown in a lot but I've got no issues with my pump so far. When I did the tune, I asked the guy to check my fuel pressure and he said there were no issues too. But is it just a good idea to change to the 255 anyway as the old unit may have been in there for so long? The 255 seems to be a direct fit for GTT (I got no soldering iron)
    • Normal speedtek issues, bin it and go cdoo# or 8hp. So many issues with these gearsets, a mate went through 3 rebuilds and multiple parts with heat, bearing and vibration issues.
    • I wouldn't go near them, they are rubber seals for a reason. Just chuck new cam cover seals, half moons and the spacers for the screws every decade or two. I add a really thin layer of silicone too and it seems to hold together OK
