Ok guys.
This is for a RB30 with R33 25 head into a R32 Skyline using RB25DE ECU
I have both the R32 RB20 and R33 RB25 ECU pinouts sheets.
1. Injector change from ECU pins 112 and 114 sorted (easy swap)
2. VCT ground at pin 113 sorted (easy fit) and 12v power to VCT solenoid hooked in with the ACC valve power in
3. TPS pins 30, 38 and 48 all good for the TPS "position"
4 HOWEVER TPS pinouts 54 and 57 on RB20 are for TPS ON or OFF but there is no corresponding R33 pinout. R33 pin 57 is used for Exhaust Temp and 54 not at all. The R33's uses this part of the TPS but how does the ECU know about it. The RB25DET wiring diagram shows the TPS ON/OFF going to some other plugs but not how it gets to the ECU
5 What is pin 17 Injection Pulse (Ti Monitor) signal. RB20DET doesn't use this pin
Cheers
Nigel
https://www.sau.com.au/forums/topic/272793-r32-rb20-vs-r33-rb25-ecu-pinouts/
  • 7 years later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
