hai all,
since i can remember this has been happening, i think this noise is coming from the ecu, i have a stock ecu and at a sertain throttle this realy high pitch beep comes on, its not loud and its not that annoying but its there and worries me that its a warning beep, the noise disapears once i either put more throttle on or less, but at that sertain level it will beep untill you change throttle. i think it does it in any gear i havnt realy taken notes to it alot. has anyone had a similar issue?
cheers
please note, I THINK its coming from the ecu, it may very well be coming from elsewere, its one of those noises where you turn your head and the noise disapears lol
https://www.sau.com.au/forums/topic/272805-high-pitch-squeel/
I don't think ECUs make noise ... as has been suggested, check your stereo setup .. I had new speakers with a crossover box installed recently and noticed the same sort of whine, apparently it was picking up engine/alternator noise. They just moved the crossover box a bit and it went away.
I get the same sound that you describe as well every now and then. Mine tends to happen at a certain engine load - I may be travelling in 4th at approx 60kmh, depress the throttle slightly due to a slight incline in the road and i get the noise. If I hold the throttle there and keep the engine loaded at that point, I can hold the noise. If I release the throttle or depress it further, obviously the load on the engine changes and the sound disappears. Kinda sounds a bit like faint feedback from speakers if you hold a microphone too close - but my stereo is never turned on.
My thoughts were that it is some sort of engine noise, possibly intake/turbo...
yea sounds alot like mine, i thought it was a boost leak or somethin, my sterio steup is pretty sound, so will have to check elsewear
Well there is that possiblity, but I have noticed that there is a really high pitch beeping type noise from the Greddy Profec B's.......
I have learnt to ignore it :D
its not actualy a beep persae, it’s a constant eeeeeeeeeeeeeeeeeeeeeeeeee
I would say that would be your best bet.
You can also see if there is a boost controlling solenoid near the turbo somewhere. If you have something like that then there is a fair chance that you have a electronic boost controller.
Something like this:
  • 4 weeks later...
mine does the exact same thing, even with the stereo off
like others hav said, if im in 4th or 5th gear at 60km/h or so and hold the throttle in one spot it will start, soon as i just increase or decrease the throttle abit it goes away, but then comes bak.... its realy weird
i dnt think its intake cos it does it in high gear, low speed and the boost needle is way down in negative land...
hmmmmmmmmmmm
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
