Hey Guys, i've gone m35 crazy!!
Whos interested in getting a dump made up for their m35?? that will be well made in stainless or whatever you like.
i can arrange a friend to make up a couple while hes making up mine. instead of paying the 700 or so jap companies are costing at the moment.
let me know!
Andrew
https://www.sau.com.au/forums/topic/272865-m35-dump-pipe-making-up-a-few/
  • Replies 182
how much? what material? how long? :banana:
+1
PLUS, what style (Split or Bellmouth), can he make one up with a pre-cat?
Can he silicone coat it to keep it looking shiny?
Pics of his previous work?
Edited by iamhe77
I'll get some photos of current work, he does lots of high end fabrication tho, you look in just about every high performance mag and you will find their work :blink:
i was thinkin of getting something done similar to the dolphin job? but i'm open to the best suggestion!! is the stock dump the same size as the dolphin job??
Flange looks tricky to source but i will pop into a shop tomorrow to see if they can get it. otherwise i will get a gasket and we will lazer cut a flange from it.
any coatings can be done also. prob best to get em ceramic coated or the like.
i'm guessing somewhere around 400, will have to wait and see.
it will not be a split housing type, dont see the point since the flange doesnt have a divider, and doubt the turbo does.
can i get some photos up of the style of dump that the m35 has? if anyone has photos of stock and aftermarket.
the photo i posted is from http://www.garagemak.com/M35aero.html
does this delete the first cat or something?? i've not had a good enough look under my car yet
That dump looks good to me.
I am reasonably sure that the first cat is on the dump pipe. Standard from Japan they then have one on the section under the passenger seat and for compliance they add another near the second one.
The standard exhaust is 2.5 inch but it has restrictive joints at the each flange, down to 2 inch.
The flange has a code and has been discussed on the forum not long ago. I will see if I can find the thread.
Cheers
Andy
Cheers
Andy
Dont worry i got that whole thread and photos on my mac to show the shop tomorrow :) t3 outlet flange.
that dump will be the go then! dumps will be 3 inch i guess. or 2 3/4 or 2.5.. i like the sound of using a 3 on a turbo tho. for less restriction
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
