  • Replies 182
Sorry Andrew -1 on this....will be able to lend you my current standard in a couple of weeks though if you still need it.
Hey mate,
Not a problem, would we be able to make up something similar to the image above off the standard shape/size?? otherwise i'll probably just use my car to make it up.
Hey mate,
I just purchased the one as per your image.
I'll get some photos of current work, he does lots of high end fabrication tho, you look in just about every high performance mag and you will find their work :D
i was thinkin of getting something done similar to the dolphin job? but i'm open to the best suggestion!! is the stock dump the same size as the dolphin job??
Flange looks tricky to source but i will pop into a shop tomorrow to see if they can get it. otherwise i will get a gasket and we will lazer cut a flange from it.
any coatings can be done also. prob best to get em ceramic coated or the like.
Dolphin dump is a different design again (much straighter)
If you are designing one, try to get it is straight as possible.
Yes the OE dump as a small cat on it. Are you able to get a cat to fit on a 3 or 2.75" dump and fit it in that space?
If so, I would be very interested as I need a cat-fitted dump pipe on mine.
Ok i have the flange, will have to get some more made this isnt the neatest.
i'll be needing a stock dump, or something soon so if anyone has that would be great. otherwise my cars off the road and dump will get pulled out..
we're open to designs on which would be best option for all. i'd rather have it like the first design, and a cat under the car in between dump and front pipe.
3inch i guess everyone is after?
If anyone is interested in a split dump pipe.
liverpool exhaust have a mild steel ceramic coated one made up.. soon to be on the market.
i'm not going to make up a split dump tho since the exhaust housing isnt split too well and i simply dont like the idea anymore. would rather have a complete 3inch all the way.
Cat after dump is not good for me personally.
I have the de-cat Kakimoto 80mm front pipe that bolts straight up to the OE dump (and to my Legalis exhaust) so I guess I will be sticking with the OE dump.
Ok, will see what the majority wants really. but it may not be a problem to modify what you want done. will obviously cost more since there is a Pussy involved..
Understandable.
Let me know if there are any options for a cat to be added to the dump. If not, no stress.
Gotta have at least one cat as I don't want all that carbon sh!t on my rear bumper.
Edited by iamhe77
Understandable.
Pussy and cars dont mix :D
if the dump we make is long enough to house a cat i dont see a problem.. just clearance may be an issue, and it will be welded on permanent i'd say/
will try get stuck into this this arvo when i finish work
What do you want a cat for anyway? :) Will talk to you on Sunday about the possibility about lending it....will be about two weeks till I get it though.
cheers
Craig
cheers
Craig
Hey mate, sounds good.
yeah i dont like cats at all, like trying to breathe thru a pillow :D
i'll either be pulling mine apart tonite to get the standard dump off to make a jig out of or borrowing one. the standard dump will be fine..
so chances i may not even need to borrow it..
thanks anyhoo :)
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
