  • Replies 182
With so much snow i've had to put off going there for a few days! but all good now. he's got the idea on how much room there is to play with..
hopefully he knocked up a few over the weekend while i was playing in knee deep powder :P
  • 4 weeks later...
Hey Guys,
there is a bit more of a hold up on these at the moment. their workshop is falling to bits! people are off sick everywhere!
i hope to get them started soon. either that or i will have to learn how to weld quickly to get them done!
will update when i know more..
Hey Guys,
/snip
Hadn't noticed mate!
In all seriousness though, can you see what the possibility of making up an 80mm or 82mm dump that fits on the standard exhaust is?
Haha possibly thats 3inch right? i'm sure thats what they will be doing.
unless i said 3,5 inch before. fitting to the standard exhaust how? the dump is going to be an exact copy of the stock one just different size and no cat stuffed in it.
76mm is 3". I am after 80mm or 82mm.
Yeah, a copy of the OE dump, just larger is what I am after... but since I have a larger front pipe, I figure I should make the most of it.
just a question re the fujitsumo legalis r .Is that a resonator behind the muffler or a cat?I'm looking at buying this system, and also a dump/front pipe without the cat on the front pipe.Perhaps those on this discussion can clarify this for me.There has been so much too-ing and Fro-ing about who can do what and what fits with what, i'm finding ia a bit hard to make sense of it. regards graham. :(
its muffler, a cat-back system is almost never supplied with a cat.
Thanks.Therefore if i did go for the fujitsubo, i would need a cat on the front pipe.Do you know if any one making up the dump pipes can supply a cat to go ?. How did any other fujitsubo owner do this if they have upgraded to a 3" or greater dump? :huh:
Thanks.Therefore if i did go for the fujitsubo, i would need a cat on the front pipe.Do you know if any one making up the dump pipes can supply a cat to go ?. How did any other fujitsubo owner do this if they have upgraded to a 3" or greater dump? :P
I have yet to get a dump as I am using the OE dump which contains a cat.
I run the Kakimoto front pipe which deletes the standard cat(s).
When I get the dump done, I will either have a Metal Cat welded into my Kakimoto pipe or I will sell the front pipe and get a dump/frontpipe/cat combo.
If I didn't live in Vic, where the police are defect-happy, I would just put a 3.25" dump on and be done with it :huh:
  • 3 weeks later...
Yo!!
i am happy to say they are actually getting worked on now.
hes done all the turbo flange side of things. and is working on the pipes inbetween the flanges. so they are close to done.
hes uses 3 inch pipe cut with an insert inbetween then which would make it about 3.5inch around the turbo flange. but the main pipe is 3 inch..
i'll have to get some photos todat to show you. they look pretty good :)
i'll get a few done in 3.25 inch outlet for the front pipe people.. but 3 inch will be fine otherwise!! unless he has already completed them as i didnt even know he started them..
Good stuff Andrew!
Does that mean that, for us front pipe people, that the dump starts at 3.5" a the outlet, then goes to 3", then back to 3.25" where it connects to the front pipe?
Or am I reading that wrong? :)
I just got off the phone to him and they are 3inch all the way. tho the turbo flange section is large dew to it being cut up and bent/modified to suit the flange.
he cant do 3.25 since he doesnt have a flange in stock. and has completed most of them.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
