excuse my n00bness i only just got it last weekend! but.....here goes,
with my SeriesII RSFour S
when i'm in first, i can hit i think 5500ish RPM then it feels like it holds at 5500RPM,
and i have to change gear.... then second will go past 5500...
has that got something to do with the ECU limiting how far i can push it in first?
or something else u think?
:banana:
Tomas.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/
oh i just read a post about 5500 Rpms and the boost dropping...
i'll have to keep an eye on my boost, my rpm and the road all at the same time so wish me luck haha
( or just get a friend to sit in and help )
:blink:
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4632158
i'm sure the 4WD models don't have traction control, only the RWD ones so it wouldn't be that.
when you say its holds at 5500 rpm does it feel like a rev limit of more of a flat spot? if it feels like a flat spot it could be a few things, could be the intake pipe sucking closed a bit, if you still have the stock exhaust or dump/front pipe you could be feeling the restriction. it also could be the slight flat spot experienced when the VVT switches off (around 5k rpm).
Edited by QWK32
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4632259
it did feel more like a flat spot than a limit maybe.. i'll try and figure exactly where and when its happening! :D
actually noticed a small exaust bandage after having a good look, would that be the source if its not sealed 100% ? :)
i think its a 3" exaust system from the looks of it
might have to get some help with this one i'm quite a n00b.
it came with an aftermarket intercooler on the front, with nice shiny pipes :)
aswell as an aftermarket pod filter and a BOV.
i'll keep investigating..
Edited by atomaly
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633250
LOL.
I still don't know how you got all that passed road worthy (let alone VicRoads).
Do you have the stock ECU or is there a piggyback installed?
Not sure why you need to hit 5.5k in 1st gear though!
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633515
LOL.
I like to hit redline in first, it's just fun :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633523
Why? Why not! lol. Besides, the old RB25 doesn't really open up till around 5k rpm.
yeah its a bit laggy down low, really opens up 4.5->6.5 , i was just a bit unsure as to why it wont get deep into the 'nice range' in 1st.
maybe give SSV a call about it??? for my case i'm saying it came with the car stock standard from the dealer :) i didnt do the RW or register it. :D
i'm not sure about if its a stock ECU i'll have a check tonight!
checked my intercooler thismorning.... its a "Blitz" from what it says on it.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633694
4.5-6.5??
You may want to check if you a "stock" turbo hiding down there.
Don't think Nissan made a turbo with that much lag from factory.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633711
4.5-6.5??
how do i know if its a stock turbo or not ? i've never had a turbo'd car b4 :D
its all rather exciting :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633806
Note that he can go past 5000 in other gears just not 1st!
what boost controller is it running? I know the AVC-R that I have you can limit boost by gear, so that could be it - but even if that WAS it , would make no sense as you can still rev past 5000 if you are still making normal boost.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633883
might have to get someone to help me out in this area,
i'm a little bit limited in what i know (n00b :D )
i'm like a sponge at the moment. :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633912
No joke it blows.
Ive done the majority of bolt ons (coil packs, plugs, FMIC, 3" turbo back, EBC, SAFCII, SITC, Coil overs, camber arms, toe arms ect ect...) and its just starting to pull pretty well just if it had a real gear box :'(
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633969
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
