excuse my n00bness i only just got it last weekend! but.....here goes,
with my SeriesII RSFour S
when i'm in first, i can hit i think 5500ish RPM then it feels like it holds at 5500RPM,
and i have to change gear.... then second will go past 5500...
has that got something to do with the ECU limiting how far i can push it in first?
or something else u think?
:banana:
Tomas.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/
oh i just read a post about 5500 Rpms and the boost dropping...
i'll have to keep an eye on my boost, my rpm and the road all at the same time so wish me luck haha
( or just get a friend to sit in and help )
:blink:
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4632158
i'm sure the 4WD models don't have traction control, only the RWD ones so it wouldn't be that.
when you say its holds at 5500 rpm does it feel like a rev limit of more of a flat spot? if it feels like a flat spot it could be a few things, could be the intake pipe sucking closed a bit, if you still have the stock exhaust or dump/front pipe you could be feeling the restriction. it also could be the slight flat spot experienced when the VVT switches off (around 5k rpm).
Edited by QWK32
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4632259
it did feel more like a flat spot than a limit maybe.. i'll try and figure exactly where and when its happening! :D
actually noticed a small exaust bandage after having a good look, would that be the source if its not sealed 100% ? :)
i think its a 3" exaust system from the looks of it
might have to get some help with this one i'm quite a n00b.
it came with an aftermarket intercooler on the front, with nice shiny pipes :)
aswell as an aftermarket pod filter and a BOV.
i'll keep investigating..
Edited by atomaly
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633250
LOL.
I still don't know how you got all that passed road worthy (let alone VicRoads).
Do you have the stock ECU or is there a piggyback installed?
Not sure why you need to hit 5.5k in 1st gear though!
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633515
LOL.
I like to hit redline in first, it's just fun :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633523
Why? Why not! lol. Besides, the old RB25 doesn't really open up till around 5k rpm.
yeah its a bit laggy down low, really opens up 4.5->6.5 , i was just a bit unsure as to why it wont get deep into the 'nice range' in 1st.
maybe give SSV a call about it??? for my case i'm saying it came with the car stock standard from the dealer :) i didnt do the RW or register it. :D
i'm not sure about if its a stock ECU i'll have a check tonight!
checked my intercooler thismorning.... its a "Blitz" from what it says on it.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633694
4.5-6.5??
You may want to check if you a "stock" turbo hiding down there.
Don't think Nissan made a turbo with that much lag from factory.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633711
4.5-6.5??
how do i know if its a stock turbo or not ? i've never had a turbo'd car b4 :D
its all rather exciting :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633806
Note that he can go past 5000 in other gears just not 1st!
what boost controller is it running? I know the AVC-R that I have you can limit boost by gear, so that could be it - but even if that WAS it , would make no sense as you can still rev past 5000 if you are still making normal boost.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633883
might have to get someone to help me out in this area,
i'm a little bit limited in what i know (n00b :D )
i'm like a sponge at the moment. :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633912
No joke it blows.
Ive done the majority of bolt ons (coil packs, plugs, FMIC, 3" turbo back, EBC, SAFCII, SITC, Coil overs, camber arms, toe arms ect ect...) and its just starting to pull pretty well just if it had a real gear box :'(
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633969
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
