No joke it blows.
Ive done the majority of bolt ons (coil packs, plugs, FMIC, 3" turbo back, EBC, SAFCII, SITC, Coil overs, camber arms, toe arms ect ect...) and its just starting to pull pretty well just if it had a real gear box :'(
:D the M35's dont come in manual at all yeah ??? unless ur a conversion king :D
i like the look of the C34's better anyway.
i was always like... *sigh* normally getting a manual = less $$. unless ur buying a stagea then its well into the other direction.
mine is a c34 mate :D
thinking of converting but mann its so pricey. prob will just get a shift kit.
yep i know man :D might be easier selling and buying a manual ? when i first looked u couldnt get a good manual for under 24k...
was just talking in general about M35's and that i dont think i'll ever own one.. hehe
C34's FTW
oh... that must mean u have leather interior ? *jealous*. i WAS thinking about modding my interior by finding a wrecked C34 with leather.. mmmm twin sunroof, manual, leather, black,. sexy.
4.5-6.5??
You may want to check if you a "stock" turbo hiding down there.
Don't think Nissan made a turbo with that much lag from factory.
it wouldn't be that the turbo is laggy it'll still come on full boost by 2500 rpm, with the RB25DET you don't start to feel the engine really pulling hard until around 4000 rpm.
Edited by QWK32
Only in RWD (6 speed manual)
OOOo so they do come in manual! :(
lol. To each their own Thomas.
Would like to compare your modded C34 with my very lightly modded M35 sometime!
sounds fun :D i'm actually keen to get a dyno to see exactly what mines pulling atm b4 i change anything (if i even need to) :D
Edited by atomaly
Yeah I've got Leather. Was one of the must haves when I was buying ;) How did you pick it?
i've actually been keeping an eye out for a year or so looking for the perfect one...(was always after black) and it fell into SSV. and i was REALLY tempted a couple of months ago but resisted until now and just went f**kit. i'm buying this cos no one else has bought it and i cant keep driving past it and wishing it was mine :D
i was also aware that manuals didnt come in leather. :(
so then i had to choose. and its easier to put leather interior in than change transmission i figured :P
the twin sunrooves just put the cherry on top :D
could be the slight flat spot experienced when the VVT switches off (around 5k rpm).
okay had a bit more of a play this weekend.
it will go past 5.5 just needs a bit of encouragement... :P i think i was just hesitant to push it hard :down:
(and after going past the first time..... second time felt like it was a tad smoother... wierd.... (a blockage of some sort???))
sortof stutters abit around the 5ish mark still..... would that be the VVT? :P
i was so glad when i saw it hit the red line in 1st :P
this dyno next week will give me a good idea of whats happening anyway!
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam camp bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
