No joke it blows.
Ive done the majority of bolt ons (coil packs, plugs, FMIC, 3" turbo back, EBC, SAFCII, SITC, Coil overs, camber arms, toe arms ect ect...) and its just starting to pull pretty well just if it had a real gear box :'(
:D the M35's dont come in manual at all yeah ??? unless ur a conversion king :D
i like the look of the C34's better anyway.
i was always like... *sigh* normally getting a manual = less $$. unless ur buying a stagea then its well into the other direction.
mine is a c34 mate :D
thinking of converting but mann its so pricey. prob will just get a shift kit.
yep i know man :D might be easier selling and buying a manual ? when i first looked u couldnt get a good manual for under 24k...
was just talking in general about M35's and that i dont think i'll ever own one.. hehe
C34's FTW
oh... that must mean u have leather interior ? *jealous*. i WAS thinking about modding my interior by finding a wrecked C34 with leather.. mmmm twin sunroof, manual, leather, black,. sexy.
4.5-6.5??
You may want to check if you a "stock" turbo hiding down there.
Don't think Nissan made a turbo with that much lag from factory.
it wouldn't be that the turbo is laggy it'll still come on full boost by 2500 rpm, with the RB25DET you don't start to feel the engine really pulling hard until around 4000 rpm.
Edited by QWK32
Only in RWD (6 speed manual)
OOOo so they do come in manual! :(
lol. To each their own Thomas.
Would like to compare your modded C34 with my very lightly modded M35 sometime!
sounds fun :D i'm actually keen to get a dyno to see exactly what mines pulling atm b4 i change anything (if i even need to) :D
Edited by atomaly
Yeah I've got Leather. Was one of the must haves when I was buying ;) How did you pick it?
i've actually been keeping an eye out for a year or so looking for the perfect one...(was always after black) and it fell into SSV. and i was REALLY tempted a couple of months ago but resisted until now and just went f**kit. i'm buying this cos no one else has bought it and i cant keep driving past it and wishing it was mine :D
i was also aware that manuals didnt come in leather. :(
so then i had to choose. and its easier to put leather interior in than change transmission i figured :P
the twin sunrooves just put the cherry on top :D
could be the slight flat spot experienced when the VVT switches off (around 5k rpm).
okay had a bit more of a play this weekend.
it will go past 5.5 just needs a bit of encouragement... :P i think i was just hesitant to push it hard :down:
(and after going past the first time..... second time felt like it was a tad smoother... wierd.... (a blockage of some sort???))
sortof stutters abit around the 5ish mark still..... would that be the VVT? :P
i was so glad when i saw it hit the red line in 1st :P
this dyno next week will give me a good idea of whats happening anyway!
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
