Hey mate ^^^ yeah all 4 of his cars were driven by him, my mum or myself..
dont get me wrong, we thrashed it as did he, 2000km a week mostly western QLD and NSW, not many quality roads out there...
but seriously the quality of my SS vs my GTR. I know what id rather have in 10 years time...
this only makes me think how much fun a current R35 GTR would be in 5-10 years (when i can probly afford it)!!
happy mods mate, thats a respectable time for a boat :) hehehe
the thing is though, people don't take into account the price difference. a gtr when new is over 100k, so you would expect it to be built better than a car that costs about half as much. it's like comparing a hyundai excel to a honda or toyota. people will tell you straight away that the hyundai is cheap shit. key word being cheap. if you want cheap you get cheap. if you want good quality you have to pay for it.
  • Replies 46
  • 2 months later...
power wise an xr6t will walk all over skylines and has heaps of space what more could you want.yes the build quality is a bit on the cheap side but for the price and taking into consideration the warranty you get.it equals out .and consider the fuel economy for such a big car it fairs resonable well.i hate when ppl say that ford is an australian company and there for shit .who do you think owns the company range rover ?? ford ofcourse hense the same gear box in xr8s as rangerover sport...
good luck with the xr6 buddy
hehe, the big boats need the power to get them going.
just being picky - but thats not exactly true. Its TORQUE that gets them going, and the XR6T has loads of it.
The power they have is comparatively pretty low when you factor in the size of the engine etc, but it more than makes up for it in torque.
Another side-effect of having so much torque on tap is wheelspin. Not as bad as say a v8 since you dont get the full torque until the turbo hits max boost and by that time you're already in motion...
Its just as well they're heavy otherwise you'd never get any traction at all. :)
Not a bad car overall...just hope its reliable for ya.
You forget that that is the inflated Australian prices. The GTRs were around 3 million to 5 million yen when new in Japan, about $40k-70k AUD, the new GTR is around what $80k?
Is a Commodore worth $150k? Ford Phase III GTHO $750k? Hell no!
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
