Help Please, Can Someone Please Lend Rb26 Coil Pack Module?...
I'm hoping someone in Vic might have a coil pack resistor for an RB26 that I can borrow for 5 mins. The R is running on 5 cylinders atm.
Basically, i've narrowed it down to cylinder no 6 (unplug the lead to the coil pack and it idles/runs the same). I've changed the spark plugs (no change), bought new splitfires (no change, dammit!) and its still not right. Running a test light to the lead to no 6 coilpack it is getting power, but wouldnt register the triggering signal (terminal E on coilpack). So the way i figure it, it should be the module, or the coil pack wiring loom. It went from running perfectly when i parked it, to running on 5 the next time i started it (2 weeks later) and the only thing i did was disconnect/reconnect the battery in between.
I'm hoping someone can lend me one, plug it in for 2 seconds, if it runs on 6 cylinders i'll then go looking for one a wreckers and i've solved my dramas. I cant afford to buy one at a wrecker and for it to not fix the problem. Funds are too low to keep splashing cash.
If you can help at all it would appreciated.
Cheers
Did you test for continuity from the ignitor plug to the coilpack plug in the coilpack loom?
No I haven't, how do I check that? I'm a beginner at this sort of stuff.
Yeah RB20 one will be the same.
I have no idea whether E or (-) is the trigger (my guess would be (E)), but one of those should run to one of the wires at the front side of the ignitor. So just go through all 12 combinations with everything disconnected.
If you dont have continuity through one of the wires then theres a prob with the loom. If you do have continuity its either the ignitor, ECU loom, or ECU.
Thanks Mat, got a multi meter from one of the guys at work so i'll take a crack at it this weekend.
I've got an RB20 ignitor box but it doesnt look the same, if the connectors plug in do you do reckon its safe to give it a crack? I dont want to fry anything...
the part number you need is 22020-05U00 most likely the rb20 one will have a part number of 22020-05U10 but by the look of nissan fast some later model rd20det's came with the gtr module so you might get lucky, i would not use anything but the U00 one.
Spent the last hour or so with the multi meter on the GTR.
There was continuity on all the wires on the loom from the module to the coil packs, so that loom is ruled out. Cylinder 6 gave all the same responses as the other working cylinders.
I unplugged the Power FC and tested continuity from the terminals from the ECU connnector (using R33 GTR ECU pinout diagram) cylinders 1-6 to the loom that plugs into the coil module. Again all was good.
I plugged in the old standard Nissan ECU (i'm supprised that it ran at all with bigger afm's and injectors!) and it still wont fire on cylinder 6.
So the ECU is sending the signal, the main loom is sending it to the connector at the back of the coil module, and the loom on the other half of the module is ending it to the coilpack. That leaves (from what I can tell) just the module itself. Its getting orders from the ECU but not sending it on the coil no 6.
The RB20 module I had looked the same, but the connectors were different (the plastic guides, pins looked the same) so i couldnt test with it. So i might just bite the bullet and buy one from a wreckers and hope that the process of elimination was correct :P
The only other option if its not the module, it it could be injector no 6 (Nismo's I bought new and have only been in the car for 2 - 3 thousand kilometers) or the the signal going goin to it.....
I'll try to totally rule out ignition issues then move on to the injectors next.
what about the coil its self?
Try swapping it with another cylinder, if the cylinder you swapped it with is then not firing then its the coil pack.
I bought a set of brand new Splitfire coils and fitted them, no diffence at all, definitely not the coils.
And I havent done a comp test because I cant see how i could blow a piston/ring when starting at car. It was perfect the last time i drove it when it was parked. On startup the next time, she was running on 5 cylinders. I cant see how it could have mechanincally failed so bad. If electrics arent to blame then youre right, i'll give it a comp test to check if its all good.
Thanks for all the help and suggestions guys, keep them comin!
  • 4 weeks later...
Found out what was actually causing the car to run rough. Turns out the inlet manifold gasket had let go into cylinder no6.
Never heard of that happening before, i expected it to be electrical or fuel related, oh well at least its running again. I finally get to drive it after about 3 months...... Cant wait :huh:
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
